Ir para o conteúdo principal
Peavy 4 String Bass String Replacement
O que você precisa
  1. Peavy 4 String Bass String Replacement, Strings: passo 1, imagem 1 %32
    • Spin the pegs in the direction which loosens the string. Either unwind the string all the way and pull it out, or cut the string after loosening it a little.
    • Repeat for all the other strings.
    Pergunte ao FixBot
    Comentar
  2. Peavy 4 String Bass String Replacement: passo 2, imagem 1 %32
    • Now that you have a bass with no strings, grab your choice of bass strings, take them out of the bag and unwind them so they are straight.
    Pergunte ao FixBot
    Comentar
  3. Peavy 4 String Bass String Replacement: passo 3, imagem 1 %32
    • Pick up your ropes and arrange them in order from thickest to thinnest, sorting from bottom to top.
    Pergunte ao FixBot
    Comentar
  4. Peavy 4 String Bass String Replacement: passo 4, imagem 1 %32
    • Starting with the thickest string (E string), feed the string through the left-most hole at the base of the bridge (pictured left).
    • Repeat what you did with the E string with next thickest string (A string).
    • Repeat again for the next thinnest (D string), and again for the thinnest string (G string).
    Pergunte ao FixBot
    Comentar
  5. Peavy 4 String Bass String Replacement: passo 5, imagem 1 %32
    • Pull the strings all the way through so the pegs at the end of the strings are touching the bridge.
    Pergunte ao FixBot
    Comentar
  6. Peavy 4 String Bass String Replacement: passo 6, imagem 1 %32
    • Starting with the E string, make sure the string is in line with the correct notch on the nut.
    • Locate the hole in the guide and feed the string through the hole so it sticks out about one centimeter.
    • Rotate the tuning peg so that the string rotates counter-clockwise until the string is taut.
    • Repeat for the other 3 strings.
    Pergunte ao FixBot
    Comentar
  7. Peavy 4 String Bass String Replacement: passo 7, imagem 1 %32
    • Make sure the strings are wrapped around the peg in the correct direction as shown.
    • If any mistakes were made, you can always unwind the string and try it again.
    Pergunte ao FixBot
    Comentar
    • Once all the strings are taut, begin tuning each string.
    • Now you have a bass with fresh strings!
    Pergunte ao FixBot
    Comentar
Conclusão
In order to get your bass sounding brand new again follow these steps and youll get a wonderful result
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 35
Ao todo: 701
