Introdução
You will be taking the wheel off of your bike, removing the tire from the wheel, and patching the hole.
Notes:
- Make sure that the wheel is fully deflated throughout the process, except for finding the hole.
- When applying the rubber cement to the hole the thinner the layer the better, for faster drying.
O que você precisa
Press the valve core while applying pressure to the tire to deflate the tire.
Locate the leak by first over inflating the tire.
Place the tire under water and look for bubbles to find the leak.
To reassemble your bike, follow these directions from step 6
Uma outra pessoa concluiu este guia.
