Ir para o conteúdo principal
Patching a Bicycle Tire Inner Tube
O que você precisa
  1. Patching a Bicycle Tire Inner Tube, Inner Tube: passo 1, imagem 1 %32
    • Press the valve core while applying pressure to the tire to deflate the tire.
  2. Patching a Bicycle Tire Inner Tube: passo 2, imagem 1 %32 Patching a Bicycle Tire Inner Tube: passo 2, imagem 2 %32
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  3. Patching a Bicycle Tire Inner Tube: passo 3, imagem 1 %32
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  4. Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: passo 4, imagem 1 %32 Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: passo 4, imagem 2 %32
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
  5. Patching a Bicycle Tire Inner Tube: passo 5, imagem 1 %32
    • Mark the hole with a marker, and completely deflate the tire.
  6. Patching a Bicycle Tire Inner Tube: passo 6, imagem 1 %32
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  7. Patching a Bicycle Tire Inner Tube: passo 7, imagem 1 %32
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
  8. Patching a Bicycle Tire Inner Tube: passo 8, imagem 1 %32
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  9. Patching a Bicycle Tire Inner Tube: passo 9, imagem 1 %32
    • Apply the patch to the area.
  10. Patching a Bicycle Tire Inner Tube: passo 10, imagem 1 %32
    • Apply pressure to the patch until the rubber cement is dry.
Conclusão
To reassemble your bike, follow these directions from step 6
Uma outra pessoa concluiu este guia.
Brett Hartt
Membro desde: 04/12/10
128.242 Reputação
Autoria de 143 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.086 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 1,890
