Ir para o conteúdo principal
Parrot Skycontroller 2 Joystick Replacement
O que você precisa
  1. Parrot Skycontroller 2 Joystick Replacement, Battery: passo 1, imagem 1 %32 Parrot Skycontroller 2 Joystick Replacement, Battery: passo 1, imagem 2 %32 Parrot Skycontroller 2 Joystick Replacement, Battery: passo 1, imagem 3 %32
    • Flip your controller face down.
    Pergunte ao FixBot
    Comentar
  2. Parrot Skycontroller 2 Joystick Replacement: passo 2, imagem 1 %32
    • Remove one 9mm screw using a #4 flathead screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Parrot Skycontroller 2 Joystick Replacement: passo 3, imagem 1 %32 Parrot Skycontroller 2 Joystick Replacement: passo 3, imagem 2 %32 Parrot Skycontroller 2 Joystick Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
    Pergunte ao FixBot
    Comentar
  4. Parrot Skycontroller 2 Joystick Replacement: passo 4, imagem 1 %32 Parrot Skycontroller 2 Joystick Replacement: passo 4, imagem 2 %32 Parrot Skycontroller 2 Joystick Replacement: passo 4, imagem 3 %32
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
    Pergunte ao FixBot
    Comentar
  5. Parrot Skycontroller 2 Joystick Replacement: passo 5, imagem 1 %32 Parrot Skycontroller 2 Joystick Replacement: passo 5, imagem 2 %32
    • Remove the battery from its brackets by pulling up on the ends of the battery.
    Pergunte ao FixBot
    Comentar
  6. Parrot Skycontroller 2 Joystick Replacement, Joystick: passo 6, imagem 1 %32
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver
    • There is a hidden screw located behind the sticker in the battery compartment.
    • Pull back the sticker with your finger nail and remove the one black 11mm screws using the Torx TR6 screwdriver
    Pergunte ao FixBot
    Comentar
  7. Parrot Skycontroller 2 Joystick Replacement: passo 7, imagem 1 %32 Parrot Skycontroller 2 Joystick Replacement: passo 7, imagem 2 %32 Parrot Skycontroller 2 Joystick Replacement: passo 7, imagem 3 %32
    • Remove the seven silver 4mm screws from around the edge of the top plate with the Torx TR6 Screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
    Pergunte ao FixBot
    Comentar
  8. Parrot Skycontroller 2 Joystick Replacement: passo 8, imagem 1 %32
    • Remove the battery compartment plate by pulling up and out.
    Pergunte ao FixBot
    Comentar
  9. Parrot Skycontroller 2 Joystick Replacement: passo 9, imagem 1 %32
    • Remove the top plate by pushing out on the corners with your hand.
    • Be careful to not pull too hard on the cable.
    Pergunte ao FixBot
    Comentar
  10. Parrot Skycontroller 2 Joystick Replacement: passo 10, imagem 1 %32 Parrot Skycontroller 2 Joystick Replacement: passo 10, imagem 2 %32
    • Remove the face plate by pulling up and out.
    • Buttons will fall out when this plate is removed.
    Pergunte ao FixBot
    Comentar
  11. Parrot Skycontroller 2 Joystick Replacement: passo 11, imagem 1 %32 Parrot Skycontroller 2 Joystick Replacement: passo 11, imagem 2 %32 Parrot Skycontroller 2 Joystick Replacement: passo 11, imagem 3 %32
    • Firmly grasp the end of either joystick.
    • Pull the joystick up and out while grasping the other side of the controller.
    • Once both joysticks have been removed, this is what it should look like.
    • Some force may be needed to remove the joysticks.
    • Repeat this process for the other side as well.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 26
Ao todo: 754
