Ir para o conteúdo principal
Parrot FLYPAD Battery Replacement
O que você precisa
  1. Parrot FLYPAD Battery Replacement, Battery: passo 1, imagem 1 %32
    • Use a T6 screwdriver to remove the six screws from the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
  2. Parrot FLYPAD Battery Replacement: passo 2, imagem 1 %32
    • Use a screwdriver to remove the two 0.7 mm screws from the battery cover.
  3. Parrot FLYPAD Battery Replacement: passo 3, imagem 1 %32
    • Separate the plastic cover from battery.
    • Avoid damaging the wires and gently remove the battery from the motherboard.
  4. Parrot FLYPAD Battery Replacement: passo 4, imagem 1 %32
    • Use fingers to gently detach the battery wires from the motherboard.
  5. Parrot FLYPAD Battery Replacement: passo 5, imagem 1 %32
    • Gently attach the wire connection from the new battery to the motherboard. Avoid touching the motherboard directly.
Conclusão
Uma outra pessoa concluiu este guia.
HUY NGUYEN
Membro desde: 04/10/17
376 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S3-G5, Liner Spring 2017 Membro de UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 Membros
Autoria de 3 guias
2Comentários do guia
Where did I get a new battery? Can’t find one.
Randy - Responder
Sorry where do I get a new parrot flypad battery. From Randy
Randy - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 1,076
