Ir para o conteúdo principal
Parrot AR.Drone 2.0 Motor Replacement
O que você precisa
Vídeo de Apresentação
  1. Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: passo 1, imagem 1 %32 Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: passo 1, imagem 2 %32
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Motor Replacement: passo 2, imagem 1 %32 Parrot AR.Drone 2.0 Motor Replacement: passo 2, imagem 2 %32
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
    how do i put the clips back in?
    kuki vier - Responder
    Are you referring to the clips in step three? If so, i highly recommend a hard, flat edged tool like a plastic spudger or flat head screw driver. Push is against the opposite side of the C clip that is opened with roughly the same force you applied to get it off. You have to be really careful that you push it directly horizontal or else you might damage the shaft or risk loosing the clip if it pops off.
    David Hoyt -
  3. Parrot AR.Drone 2.0 Motor Replacement: passo 3, imagem 1 %32
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Motor Replacement: passo 4, imagem 1 %32 Parrot AR.Drone 2.0 Motor Replacement: passo 4, imagem 2 %32 Parrot AR.Drone 2.0 Motor Replacement: passo 4, imagem 3 %32
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
  5. Parrot AR.Drone 2.0 Motor Replacement, Motor: passo 5, imagem 1 %32 Parrot AR.Drone 2.0 Motor Replacement, Motor: passo 5, imagem 2 %32
    • Disconnect the connector at the bottom of the motor assembly.
  6. Parrot AR.Drone 2.0 Motor Replacement: passo 6, imagem 1 %32
    • Remove the three 5mm screws on the top of the motor assembly with a PH00 bit.
  7. Parrot AR.Drone 2.0 Motor Replacement: passo 7, imagem 1 %32
    • Remove the three 5mm screws on the bottom again using a PH00 bit.
    • The three screws from the top are different from the three screws on the bottom.
  8. Parrot AR.Drone 2.0 Motor Replacement: passo 8, imagem 1 %32 Parrot AR.Drone 2.0 Motor Replacement: passo 8, imagem 2 %32
    • Carefully wiggle out the motor assembly out of the arm.
Conclusão
5 outras pessoas executaram este guia.
David Hoyt
Membro desde: 04/09/10
4.053 Reputação
Autoria de 41 guias
Equipe
Cal Poly, Team 25-89, Amido Spring 2010 Membro de Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membros
Autoria de 61 guias
2 comentários
are the motors different on each side?
dbksoft - Responder
I need to know this also. replaced cross.member but did not put motors in original spots now my drone goes crazy and erratic
Steven Maloney -
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 47
Ao todo: 5,861
