Ir para o conteúdo principal
Pantech Matrix Power Button Replacement
O que você precisa
  1. Pantech Matrix Power Button Replacement, Phone Orientation: passo 1, imagem 1 %32
    • Place phone with screen side facing toward you.
    Pergunte ao FixBot
    Comentar
  2. Pantech Matrix Power Button Replacement, Phone Orientation: passo 2, imagem 1 %32
    • Flip phone over so screen side is now facing down.
    Pergunte ao FixBot
    Comentar
  3. Pantech Matrix Power Button Replacement, Remove Back Cover: passo 3, imagem 1 %32 Pantech Matrix Power Button Replacement, Remove Back Cover: passo 3, imagem 2 %32
    • Gently slide the backside phone cover off exposing the battery underneath.
    Pergunte ao FixBot
    Comentar
  4. Pantech Matrix Power Button Replacement, Lift Battery: passo 4, imagem 1 %32
    • Carefully lift the battery up from where the spudger is pointed.
    Pergunte ao FixBot
    Comentar
  5. Pantech Matrix Power Button Replacement, Remove Battery: passo 5, imagem 1 %32
    • Remove the battery from its dock.
    Pergunte ao FixBot
    Comentar
  6. Pantech Matrix Power Button Replacement, Slide SIM Card Out: passo 6, imagem 1 %32 Pantech Matrix Power Button Replacement, Slide SIM Card Out: passo 6, imagem 2 %32 Pantech Matrix Power Button Replacement, Slide SIM Card Out: passo 6, imagem 3 %32
    • Slide the SIM Card out of its dock.
    Pergunte ao FixBot
    Comentar
  7. Pantech Matrix Power Button Replacement, Remove Phone Screws: passo 7, imagem 1 %32 Pantech Matrix Power Button Replacement, Remove Phone Screws: passo 7, imagem 2 %32
    • Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
    Pergunte ao FixBot
    Comentar
  8. Pantech Matrix Power Button Replacement, Remove Phone Casing: passo 8, imagem 1 %32 Pantech Matrix Power Button Replacement, Remove Phone Casing: passo 8, imagem 2 %32
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside.
    Pergunte ao FixBot
    Comentar
  9. Pantech Matrix Power Button Replacement, Remove Camera Screws: passo 9, imagem 1 %32 Pantech Matrix Power Button Replacement, Remove Camera Screws: passo 9, imagem 2 %32
    • Place phone with exposed motherboard facing you.
    • Use a PH000 driver to remove the five 2 mm screws holding the camera in place.
    Pergunte ao FixBot
    Comentar
  10. Pantech Matrix Power Button Replacement, Remove Motherboard: passo 10, imagem 1 %32
    • Carefully lift up to motherboard to expose the power button.
    Pergunte ao FixBot
    Comentar
  11. Pantech Matrix Power Button Replacement, Remove Power Button: passo 11, imagem 1 %32 Pantech Matrix Power Button Replacement, Remove Power Button: passo 11, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Locate the power button.
    • Grasp the power button with metal tweezers and pull gently to remove.
    Pergunte ao FixBot
    Comentar
Conclusão
Zeel Patel
Membro desde: 10/13/14
1.096 Reputação
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 24
Ao todo: 586
