Ir para o conteúdo principal
Panasonic SC-PM31 Fan Replacement
O que você precisa
  1. Panasonic SC-PM31 Fan Replacement, Removing the side and back screws: passo 1, imagem 1 %32 Panasonic SC-PM31 Fan Replacement, Removing the side and back screws: passo 1, imagem 2 %32 Panasonic SC-PM31 Fan Replacement, Removing the side and back screws: passo 1, imagem 3 %32
    • Remove the five 9 mm #2 Phillips screws from the side panel nearest the power button.
    • Repeat the process for the opposite panel.
    • Remove the two 15 mm #2 Phillips screws from the back of the top panel.
    • Remove the middle 10mm #2 Phillips screw from the back of the top panel.
    Pergunte ao FixBot
    Comentar
  2. Panasonic SC-PM31 Fan Replacement, Removing the panels: passo 2, imagem 1 %32 Panasonic SC-PM31 Fan Replacement, Removing the panels: passo 2, imagem 2 %32
    • If you do not have a plastic opening tool, you can open the system using your finger. However, if you choose to use your hands, make sure to wear gloves. The panel is very sharp.
    • Swing the back half of the panel slightly away from the unit. Then, starting at the top back corner, slide plastic opening tool through the created gap from back to front. The panel should pop off. Repeat the process on the opposite panel.
    Pergunte ao FixBot
    Comentar
  3. Panasonic SC-PM31 Fan Replacement, Removing the white ribbon wire: passo 3, imagem 1 %32
    • Looking in through the side nearest the power button, use your fingers to pull the white ribbon connection toward you, away from the rear circuit board.
    • The process will require the use of moderate force and can be eased by wiggling the ribbon during removal.
    Pergunte ao FixBot
    Comentar
  4. Panasonic SC-PM31 Fan Replacement, Removing the top panel: passo 4, imagem 1 %32 Panasonic SC-PM31 Fan Replacement, Removing the top panel: passo 4, imagem 2 %32
    • Remove the top panel. You will need to slightly bend the plastic tab outwards, to undo the clasp that is attached to the top.
    • When reassembling the device, reattach the white ribbon wire (Step 3) before replacing the top panel.
    Pergunte ao FixBot
    Comentar
  5. Panasonic SC-PM31 Fan Replacement, Removing the back panel screws: passo 5, imagem 1 %32
    • Remove the eight 9.5 mm #2 Phillips screws attaching the back to the device.
    Pergunte ao FixBot
    Comentar
  6. Panasonic SC-PM31 Fan Replacement, Removing the back panel: passo 6, imagem 1 %32 Panasonic SC-PM31 Fan Replacement, Removing the back panel: passo 6, imagem 2 %32 Panasonic SC-PM31 Fan Replacement, Removing the back panel: passo 6, imagem 3 %32
    • With a gentle tug, unplug the red and black cable from the tan circuit board.
    • Using both hands, unlock the plastic back panel from the metal clasps (located on the sides of the unit) by pulling the plastic away from the metal. Focus on undoing first one clasp, then the other.
    • Slide the back panel toward you and off of the unit.
    Pergunte ao FixBot
    Comentar
  7. Panasonic SC-PM31 Fan Replacement, Removing the fan.: passo 7, imagem 1 %32 Panasonic SC-PM31 Fan Replacement, Removing the fan.: passo 7, imagem 2 %32 Panasonic SC-PM31 Fan Replacement, Removing the fan.: passo 7, imagem 3 %32
    • Flip the back panel over and locate the four clasps holding the fan in place.
    • One by one, unlock each clasp by pulling it outwards and gently lifting the fan up and away from it.
    • Remove the fan by lifting it gently away from the back panel.
    Pergunte ao FixBot
    Comentar
Conclusão
Jessica Chao
Membro desde: 09/29/14
650 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 13-7, Forte Fall 2014 Membro de Cal Poly, Team 13-7, Forte Fall 2014
CPSU-FORTE-F14S13G7
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 33
Ao todo: 1,497
