Ir para o conteúdo principal
Panasonic SA-HT810V DVD Drive Replacement
O que você precisa
  1. Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: passo 1, imagem 1 %32 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: passo 1, imagem 2 %32 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: passo 1, imagem 3 %32
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove the screw that is on the right side of the panel facing you.
    • Remove all screws with a phillips head screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Panasonic SA-HT810V DVD Drive Replacement: passo 2, imagem 1 %32 Panasonic SA-HT810V DVD Drive Replacement: passo 2, imagem 2 %32
    • Rotate the device so that the back faces you.
    • Using a phillips head screw driver, locate and remove the two screws highlighted by the red circles in image one.
    Pergunte ao FixBot
    Comentar
  3. Panasonic SA-HT810V DVD Drive Replacement: passo 3, imagem 1 %32
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
    Pergunte ao FixBot
    Comentar
  4. Panasonic SA-HT810V DVD Drive Replacement: passo 4, imagem 1 %32 Panasonic SA-HT810V DVD Drive Replacement: passo 4, imagem 2 %32 Panasonic SA-HT810V DVD Drive Replacement: passo 4, imagem 3 %32
    • Pull up the two tabs on top
    • Pull the the three tabs on the side. One is on the left, and two are on the right side of the device when it is facing you.
    • Depress the four tabs on the bottom of the device with a flat head screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Panasonic SA-HT810V DVD Drive Replacement: passo 5, imagem 1 %32
    • Carefully pull off the front panel of the device.
    • The front is attached to the device with cables so be careful when removing.
    Pergunte ao FixBot
    Comentar
  6. Panasonic SA-HT810V DVD Drive Replacement: passo 6, imagem 1 %32 Panasonic SA-HT810V DVD Drive Replacement: passo 6, imagem 2 %32
    • Remove the four screws around the DVD drive with a phillips head screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Panasonic SA-HT810V DVD Drive Replacement: passo 7, imagem 1 %32
    • The DVD player is attached to the power supply.
    • Remove the wire attaching it by firmly pulling on the wire until it releases.
    Pergunte ao FixBot
    Comentar
  8. Panasonic SA-HT810V DVD Drive Replacement: passo 8, imagem 1 %32
    • Flip the DVD drive so that the bottom is facing you.
    • Pull on the blue ribbon cable until it releases.
    • To place the new DVD drive in just follow these steps in reverse.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 16-5, Maness Spring 2010 Membro de Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 55
Ao todo: 1,954
