Ir para o conteúdo principal
Panasonic RQ-2102 Buttons Replacement
O que você precisa
  1. Panasonic RQ-2102 Buttons Replacement, Buttons: passo 1, imagem 1 %32 Panasonic RQ-2102 Buttons Replacement, Buttons: passo 1, imagem 2 %32 Panasonic RQ-2102 Buttons Replacement, Buttons: passo 1, imagem 3 %32
    • Remove the three screws from the back of the device body.
    • Remove both screws from battery compartment.
    • Remove the back.
    • Make sure not to pull apart the cords that connect the device.
    Pergunte ao FixBot
    Comentar
  2. Panasonic RQ-2102 Buttons Replacement: passo 2, imagem 1 %32 Panasonic RQ-2102 Buttons Replacement: passo 2, imagem 2 %32 Panasonic RQ-2102 Buttons Replacement: passo 2, imagem 3 %32
    • Remove screws from the sides of the silver button pin roller.
    • Pry out the silver bar
    • Remove the desired button
    Pergunte ao FixBot
    Comentar
  3. Panasonic RQ-2102 Buttons Replacement: passo 3, imagem 1 %32 Panasonic RQ-2102 Buttons Replacement: passo 3, imagem 2 %32 Panasonic RQ-2102 Buttons Replacement: passo 3, imagem 3 %32
    • Insert the new button in place of the old button.
    • Put the silver pin roller back into its place over the buttons.
    • Put screws back into their original places by the sides of the silver pin roller.
    • If new buttons are not available, clean old buttons with a wet rag.
    • If the buttons do not work, ensure they are in their correct positions.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 38
Ao todo: 1,190
