Ir para o conteúdo principal
Panasonic Lumix DMC-ZS60 Camera Lens Replacement
O que você precisa
  1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Battery: passo 1, imagem 1 %32
    • Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
  2. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 2, imagem 2 %32
    • Push up the black tab on the right-hand-side to spring release the battery.
  3. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 3, imagem 1 %32
    • Remove the battery by sliding it out from the camera.
  4. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: passo 4, imagem 1 %32 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: passo 4, imagem 2 %32 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: passo 4, imagem 3 %32
    • Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
  5. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 5, imagem 1 %32
    • Pry off back casing and set aside.
  6. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 6, imagem 1 %32 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull the right side control dial circuit board up.
    • Use tweezers to pry up the white retaining flap and gently pull the circuit board out.
  7. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 7, imagem 1 %32 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 7, imagem 2 %32 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 7, imagem 3 %32
    • Flip the LCD screen to the left.
    • Unscrew the two 3mm on the top right side using the Phillips #000 Screwdriver.
    • Lift the gray plate cover off.
  8. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 8, imagem 1 %32 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 8, imagem 2 %32
    • Use tweezers to pry up the black retaining flat and gently pull to free the LCD screen from the device.
  9. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Motherboard: passo 9, imagem 1 %32
    • Remove these three 3 mm screws with a Phillips #000 screwdriver.
  10. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 10, imagem 1 %32 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 10, imagem 2 %32 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 10, imagem 3 %32
    Comprar
    • Disconnect these 9 ribbon cables from the motherboard. One ribbon cable is hidden underneath the larger one on the left.
    • Use tweezers to first lift up the retaining flaps for each connector, then pull out the ribbon cable.
  11. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 11, imagem 1 %32 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 11, imagem 2 %32
    • Now you will able to lift the motherboard up and it will only be connected by two cables.
    • To fully remove the motherboard, you will have to solder the metal in order to remove the wires.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
  12. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Camera Lens: passo 12, imagem 1 %32 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Camera Lens: passo 12, imagem 2 %32
    • Unscrew the three 3mm screws attached to the plate cover using a Phillips #000 Screwdriver.
    • Pull off the plate cover to uncover the camera lens.
  13. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 13, imagem 1 %32 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: passo 13, imagem 2 %32
    • Lift the camera lens from the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
A few years ago, I had a 30x zoom like this. It got a spot of dust inside the lens that showed up in photos, especially zoomed-in. I tried to unscrew the front of the lens to clean out the dust but the plastic broke, ruining the camera.
Fred Oswald - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 61
Duração total: 2,307
