Ir para o conteúdo principal
Panasonic Lumix DMC-GF2 LCD Replacement
O que você precisa
    1. Panasonic Lumix DMC-GF2 LCD Replacement, Battery: passo 1, imagem 1 %32
      • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
      Pergunte ao FixBot
      Comentar
    2. Panasonic Lumix DMC-GF2 LCD Replacement: passo 2, imagem 1 %32 Panasonic Lumix DMC-GF2 LCD Replacement: passo 2, imagem 2 %32
      • Push the small black tab that holds the battery with your finger to release the battery.
      • Use your fingers to pull the battery out of the camera.
      Pergunte ao FixBot
      Comentar
    1. Panasonic Lumix DMC-GF2 LCD Replacement, Back Cover: passo 3, imagem 1 %32 Panasonic Lumix DMC-GF2 LCD Replacement, Back Cover: passo 3, imagem 2 %32 Panasonic Lumix DMC-GF2 LCD Replacement, Back Cover: passo 3, imagem 3 %32
      • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
      Pergunte ao FixBot
      Comentar
    2. Panasonic Lumix DMC-GF2 LCD Replacement: passo 4, imagem 1 %32 Panasonic Lumix DMC-GF2 LCD Replacement: passo 4, imagem 2 %32 Panasonic Lumix DMC-GF2 LCD Replacement: passo 4, imagem 3 %32
      • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
      • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
      • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
      Pergunte ao FixBot
      Comentar
    3. Panasonic Lumix DMC-GF2 LCD Replacement: passo 5, imagem 1 %32
      • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
      Pergunte ao FixBot
      Comentar
    4. Panasonic Lumix DMC-GF2 LCD Replacement: passo 6, imagem 1 %32
      • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
      Pergunte ao FixBot
      Comentar
    5. Panasonic Lumix DMC-GF2 LCD Replacement: passo 7, imagem 1 %32
      • Using a spudger, lift up and remove the plastic cover piece from the back cover.
      • Plastic cover may fall off without prying.
      Pergunte ao FixBot
      Comentar
    6. Panasonic Lumix DMC-GF2 LCD Replacement: passo 8, imagem 1 %32
      • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
      Pergunte ao FixBot
      Comentar
    7. Panasonic Lumix DMC-GF2 LCD Replacement: passo 9, imagem 1 %32
      • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
      • Metal cover may fall off without prying.
      Pergunte ao FixBot
      Comentar
    1. Panasonic Lumix DMC-GF2 LCD Replacement, LCD screen: passo 10, imagem 1 %32
      • Using your fingers, push down on the small, metal hooks that are a part of the metal cover and attach on top of the LCD screen.
      Pergunte ao FixBot
      Comentar
    2. Panasonic Lumix DMC-GF2 LCD Replacement: passo 11, imagem 1 %32
      • Using your fingers, remove the LCD screen from the metal cover. This may require some back and forth movements of the LCD screen until it detaches completely from the bottom hooks.
      • Careful not to rip the yellow ribbons when removing the LCD screen from the metal cover.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Kingsley East
Membro desde: 10/30/16
474 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 5-9, Williams Fall 2016 Membro de Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
3 Membros
Autoria de 11 guias
3Comentários do guia
In Step 3 above, you definitely need to remove the hot shoe cover, and the 4 screws underneath that in order to remove the back of the camera safely! If you don’t, the back cover only comes off with excessive force and then causes damage to the portion of the bracket holding it in place beneath the hot shoe - trust me, I know from experience.
karl - Responder Compartilhar
after removing the hot shoe cover i cannot see the screws you are talking about. I have undone the 6 screws mentioned in the guide, but the back of the camera still does not want to come off. I don't want to force it, but i can't see any more screws holding it in. can anyone help?
fasta rasta - Responder Compartilhar
i found the screws, they are hidden under a small metal spring/plate in the hot shoe. this plate need to be levered out with a small screwdriver, it then slides back from the body revealing the four screws. to undo the back cover remove the back two screws, the other two hold on the front cover. service manual for this camera can be found here - https://www.manualslib.com/download/2482... procedure is pictured on page 34
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 17
Últimos 30 dias: 67
Ao todo: 4,664
