Introdução
Use this guide to correctly replace the earpiece in one of the handsets in your Panasonic phone. Replacing the earpiece can result in better quality sound being transmitted through the handset as well as reduced static. This repair will require soldering.
This procedure applies to all handsets that are given with the device.
If you need help with soldering, review how to solder and desolder connections.
O que você precisa
In order to remove the back of the phone, unscrew the two screws at the bottom corners on the back of the phone.
Uma outra pessoa concluiu este guia.
