Ir para o conteúdo principal
Panasonic DVD-RV31 Player Front Panel Replacement
O que você precisa
    1. Panasonic DVD-RV31 Player Front Panel Replacement, Disk Tray Cover: passo 1, imagem 1 %32
      • Eject the disk tray from the DVD player before removing power supply.
      Pergunte ao FixBot
      Comentar
    2. Panasonic DVD-RV31 Player Front Panel Replacement: passo 2, imagem 1 %32
      • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
      Pergunte ao FixBot
      Comentar
    1. Panasonic DVD-RV31 Player Front Panel Replacement, Outer Case: passo 3, imagem 1 %32 Panasonic DVD-RV31 Player Front Panel Replacement, Outer Case: passo 3, imagem 2 %32
      • Remove the three screws running along the back edge of case cover.
      • Remove the two screws from each side of the case cover.
      Pergunte ao FixBot
      Comentar
    2. Panasonic DVD-RV31 Player Front Panel Replacement: passo 4, imagem 1 %32
      • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
      Pergunte ao FixBot
      Comentar
    1. Panasonic DVD-RV31 Player Front Panel Replacement, Front Panel: passo 5, imagem 1 %32 Panasonic DVD-RV31 Player Front Panel Replacement, Front Panel: passo 5, imagem 2 %32
      • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
      Pergunte ao FixBot
      Comentar
Conclusão
Kevin
Membro desde: 04/26/11
375 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 18-20, Garner Spring 2011 Membro de Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Membros
Autoria de 25 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 32
Ao todo: 2,927
