Ir para o conteúdo principal
Panasonic DVD-RV31 Player Disc Retainer Replacement
O que você precisa
  1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Tray Cover: passo 1, imagem 1 %32
    • Eject the disk tray from the DVD player before removing power supply.
    Pergunte ao FixBot
    Comentar
  2. Panasonic DVD-RV31 Player Disc Retainer Replacement: passo 2, imagem 1 %32
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
    Pergunte ao FixBot
    Comentar
  3. Panasonic DVD-RV31 Player Disc Retainer Replacement, Outer Case: passo 3, imagem 1 %32 Panasonic DVD-RV31 Player Disc Retainer Replacement, Outer Case: passo 3, imagem 2 %32
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
    Pergunte ao FixBot
    Comentar
  4. Panasonic DVD-RV31 Player Disc Retainer Replacement: passo 4, imagem 1 %32
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
    Pergunte ao FixBot
    Comentar
  5. Panasonic DVD-RV31 Player Disc Retainer Replacement, Front Panel: passo 5, imagem 1 %32 Panasonic DVD-RV31 Player Disc Retainer Replacement, Front Panel: passo 5, imagem 2 %32
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
    Pergunte ao FixBot
    Comentar
  6. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: passo 6, imagem 1 %32 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: passo 6, imagem 2 %32 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: passo 6, imagem 3 %32
    • Locate the four screws securing the disk drive assembly. There are two on each side.
    • Use a narrow screwdriver to remove all four screws.
    • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
    Pergunte ao FixBot
    Comentar
  7. Panasonic DVD-RV31 Player Disc Retainer Replacement: passo 7, imagem 1 %32
    • Lift assembly by the front to pull metal bracket from the power board.
    • Pull up back end and lift drive out.
    Pergunte ao FixBot
    Comentar
  8. Panasonic DVD-RV31 Player Disc Retainer Replacement: passo 8, imagem 1 %32
    • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
    • Lift bracket off and reserve for re-assembly.
    Pergunte ao FixBot
    Comentar
  9. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: passo 9, imagem 1 %32 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: passo 9, imagem 2 %32 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: passo 9, imagem 3 %32
    • Grasp the bridge above the wheel and push the tabs on the side as shown.
    • Pull down firmly and away from the laser housing.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Kevin
Membro desde: 04/26/11
375 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 18-20, Garner Spring 2011 Membro de Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 5,852
