Ir para o conteúdo principal
Panasonic DMC-FZ70 Viewfinder Replacement
O que você precisa
    1. Panasonic DMC-FZ70 Viewfinder Replacement, Back Panel: passo 1, imagem 1 %32 Panasonic DMC-FZ70 Viewfinder Replacement, Back Panel: passo 1, imagem 2 %32
      • All screws should be removed using a Phillips #0 screwdriver.
      • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
      Pergunte ao FixBot
      Comentar
    2. Panasonic DMC-FZ70 Viewfinder Replacement: passo 2, imagem 1 %32 Panasonic DMC-FZ70 Viewfinder Replacement: passo 2, imagem 2 %32
      • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
      Pergunte ao FixBot
      Comentar
    3. Panasonic DMC-FZ70 Viewfinder Replacement: passo 3, imagem 1 %32 Panasonic DMC-FZ70 Viewfinder Replacement: passo 3, imagem 2 %32
      • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
      Pergunte ao FixBot
      Comentar
    4. Panasonic DMC-FZ70 Viewfinder Replacement: passo 4, imagem 1 %32 Panasonic DMC-FZ70 Viewfinder Replacement: passo 4, imagem 2 %32
      • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
      • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
      Pergunte ao FixBot
      Comentar
    5. Panasonic DMC-FZ70 Viewfinder Replacement: passo 5, imagem 1 %32
      • Proceed to remove the four 5mm Phillips screws that you just uncovered.
      Pergunte ao FixBot
      Comentar
    6. Panasonic DMC-FZ70 Viewfinder Replacement: passo 6, imagem 1 %32
      • Slowly pull on both side of the camera, until both halves begin to separate from each other.
      • Do not pull too hard, as both halves are held together with ZIF connector cables.
      Pergunte ao FixBot
      Comentar
    7. Panasonic DMC-FZ70 Viewfinder Replacement: passo 7, imagem 1 %32 Panasonic DMC-FZ70 Viewfinder Replacement: passo 7, imagem 2 %32 Panasonic DMC-FZ70 Viewfinder Replacement: passo 7, imagem 3 %32
      • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
      • Carefully pull the ribbon cables out of the slot once they have been released.
      • Only the two indicated connectors need to be removed to separate the two halves of the camera.
      Pergunte ao FixBot
      Comentar
    1. Panasonic DMC-FZ70 Viewfinder Replacement, Viewfinder: passo 8, imagem 1 %32 Panasonic DMC-FZ70 Viewfinder Replacement, Viewfinder: passo 8, imagem 2 %32
      • Using a plastic opening tool, flip up the black switch on the ZIF connector that attaches the viewfinder to the motherboard.
      • Once the connector has been opened, gently pull the cable from its slot.
      Pergunte ao FixBot
      Comentar
    2. Panasonic DMC-FZ70 Viewfinder Replacement: passo 9, imagem 1 %32 Panasonic DMC-FZ70 Viewfinder Replacement: passo 9, imagem 2 %32
      • Holding the sides of the viewfinder, pull it out of the camera.
      • Removing the viewfinder requires a strong, yet steady pull.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 21-3, Maness Winter 2017 Membro de Cal Poly, Team 21-3, Maness Winter 2017
CPSU-MANESS-W17S21G3
6 Membros
Autoria de 12 guias
1Comentário do guia
Wow, this is very HELPFUL! I saved it with Zotero in case I need it one day. I'm simply looking for an eyepiece extender and/or rubber eyepiece combo. If you have a good source Photo Supply you'd recommend, please do so.
Mr. Phil - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 27
Ao todo: 1,820
