Introdução
Be sure to remove the battery and SD card before opening the camera to get to the screen component.
O que você precisa
Open and rotate the screen, then remove the screw(3.5mm Philips) indicated with a screwdriver.
Then, rotate the screen 180 degrees and remove the screw on the opposite side.
