Ir para o conteúdo principal
Panasonic ARC ES-LT3N Battery Replacement
O que você precisa
    1. Panasonic ARC ES-LT3N Battery Replacement, Back Casing: passo 1, imagem 1 %32 Panasonic ARC ES-LT3N Battery Replacement, Back Casing: passo 1, imagem 2 %32
      • Flip the razor over so the back is facing you.
      Pergunte ao FixBot
      Comentar
    2. Panasonic ARC ES-LT3N Battery Replacement: passo 2, imagem 1 %32 Panasonic ARC ES-LT3N Battery Replacement: passo 2, imagem 2 %32
      • Using a Phillips #00 screwdriver, remove the 6 mm screw just above the charger port.
      Pergunte ao FixBot
      Comentar
    3. Panasonic ARC ES-LT3N Battery Replacement: passo 3, imagem 1 %32 Panasonic ARC ES-LT3N Battery Replacement: passo 3, imagem 2 %32
      • Slide the plastic cover at the bottom of the razor downward to remove.
      Pergunte ao FixBot
      Comentar
    4. Panasonic ARC ES-LT3N Battery Replacement: passo 4, imagem 1 %32 Panasonic ARC ES-LT3N Battery Replacement: passo 4, imagem 2 %32
      • Lift up the rear casing from the bottom of the razor.
      • This may require you to gently pry it apart with you fingers.
      • Lift up the rear casing from the sides of the razor.
      • Pull rear casing up and off razor.
      • Be careful not to break any plastic!
      Pergunte ao FixBot
      Comentar
    1. Panasonic ARC ES-LT3N Battery Replacement, Battery: passo 5, imagem 1 %32
      • Using the Phillips 00 driver bit, remove six screws (12mm) from the battery case.
      Pergunte ao FixBot
      Comentar
    2. Panasonic ARC ES-LT3N Battery Replacement: passo 6, imagem 1 %32
      • Remove battery case.
      Pergunte ao FixBot
      Comentar
    3. Panasonic ARC ES-LT3N Battery Replacement: passo 7, imagem 1 %32 Panasonic ARC ES-LT3N Battery Replacement: passo 7, imagem 2 %32
      • Remove old battery by lifting the battery up and left.
      • There are plastic brackets holding the battery on the right. Removing up and left ensures that the brackets will not be damaged and the battery will not come loose.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
1Comentário do guia
Where does one actually find the replacement batteries though?
WooKstah - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 47
Ao todo: 2,449
