Ir para o conteúdo principal
Palm TX Motherboard Replacement
O que você precisa
  1. Palm TX Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Palm TX Motherboard Replacement, Back Panel: passo 1, imagem 2 %32
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
    Pergunte ao FixBot
    Comentar
  2. Palm TX Motherboard Replacement: passo 2, imagem 1 %32
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
    Pergunte ao FixBot
    Comentar
  3. Palm TX Motherboard Replacement: passo 3, imagem 1 %32 Palm TX Motherboard Replacement: passo 3, imagem 2 %32
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
    Pergunte ao FixBot
    Comentar
  4. Palm TX Motherboard Replacement: passo 4, imagem 1 %32 Palm TX Motherboard Replacement: passo 4, imagem 2 %32
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
    Pergunte ao FixBot
    Comentar
  5. Palm TX Motherboard Replacement: passo 5, imagem 1 %32 Palm TX Motherboard Replacement: passo 5, imagem 2 %32
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
    Pergunte ao FixBot
    Comentar
  6. Palm TX Motherboard Replacement, Battery Pack: passo 6, imagem 1 %32 Palm TX Motherboard Replacement, Battery Pack: passo 6, imagem 2 %32
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
    Pergunte ao FixBot
    Comentar
  7. Palm TX Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 Palm TX Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
    Pergunte ao FixBot
    Comentar
  8. Palm TX Motherboard Replacement: passo 8, imagem 1 %32 Palm TX Motherboard Replacement: passo 8, imagem 2 %32
    • Lift the mother board out of the device.
    • A weak adhesive attaches the motherboard to the device.
    • The red wire in the picture will not be attached to your device at this point.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 1-15, Amido Winter 2011 Membro de Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Membros
Autoria de 9 guias
1Comentário do guia
Nicely done!
Matthew Newsom - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 47
Ao todo: 4,010
