Ir para o conteúdo principal
Palm TX Back Panel Replacement
O que você precisa
  1. Palm TX Back Panel Replacement, Back Panel: passo 1, imagem 1 %32 Palm TX Back Panel Replacement, Back Panel: passo 1, imagem 2 %32
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
    Pergunte ao FixBot
    Comentar
  2. Palm TX Back Panel Replacement: passo 2, imagem 1 %32
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
    Pergunte ao FixBot
    Comentar
  3. Palm TX Back Panel Replacement: passo 3, imagem 1 %32 Palm TX Back Panel Replacement: passo 3, imagem 2 %32
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
    Pergunte ao FixBot
    Comentar
  4. Palm TX Back Panel Replacement: passo 4, imagem 1 %32 Palm TX Back Panel Replacement: passo 4, imagem 2 %32
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
    Pergunte ao FixBot
    Comentar
  5. Palm TX Back Panel Replacement: passo 5, imagem 1 %32 Palm TX Back Panel Replacement: passo 5, imagem 2 %32
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 1-15, Amido Winter 2011 Membro de Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 46
Ao todo: 2,014
