Ir para o conteúdo principal
PSP Go Trigger buttons Replacement
O que você precisa
  1. PSP Go Trigger buttons Replacement, Back Cover: passo 1, imagem 1 %32 PSP Go Trigger buttons Replacement, Back Cover: passo 1, imagem 2 %32
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
    Pergunte ao FixBot
    Comentar
  2. PSP Go Trigger buttons Replacement: passo 2, imagem 1 %32 PSP Go Trigger buttons Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
    Pergunte ao FixBot
    Comentar
  3. PSP Go Trigger buttons Replacement, Top Cover: passo 3, imagem 1 %32
    • Pull the top cover upwards gently from its housing.
    Pergunte ao FixBot
    Comentar
  4. PSP Go Trigger buttons Replacement, Trigger buttons: passo 4, imagem 1 %32
    • The top cover will most likely come off during the repair, so might as well take it off now. Pull it upwards gently from its housing.
    Pergunte ao FixBot
    Comentar
  5. PSP Go Trigger buttons Replacement: passo 5, imagem 1 %32
    • The procedure is exactly the same for the left trigger button.
    • Use a plastic opening tool to gently flip up the left trigger connector.
    Pergunte ao FixBot
    Comentar
  6. PSP Go Trigger buttons Replacement: passo 6, imagem 1 %32 PSP Go Trigger buttons Replacement: passo 6, imagem 2 %32
    • Unscrew the lone Phillips screw holding the trigger in place. Remove both trigger and retaining plate from the PSP Go.
    • If necessary, repeat steps 2 and 3 to remove the right trigger button.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 22
Últimos 30 dias: 107
Ao todo: 13,127
