Ir para o conteúdo principal
PSP 300xc Trigger Buttons Replacement
O que você precisa
  1. PSP 300xc Trigger Buttons Replacement, Battery: passo 1, imagem 1 %32 PSP 300xc Trigger Buttons Replacement, Battery: passo 1, imagem 2 %32
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
    Pergunte ao FixBot
    Comentar
  2. PSP 300xc Trigger Buttons Replacement, Front Case: passo 2, imagem 1 %32
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
    Pergunte ao FixBot
    Comentar
  3. PSP 300xc Trigger Buttons Replacement: passo 3, imagem 1 %32 PSP 300xc Trigger Buttons Replacement: passo 3, imagem 2 %32
    • Remove four Phillips screws from the back of the PSP.
    Pergunte ao FixBot
    Comentar
  4. PSP 300xc Trigger Buttons Replacement: passo 4, imagem 1 %32
    • Remove two Phillips screws from the top of the PSP.
    Pergunte ao FixBot
    Comentar
  5. PSP 300xc Trigger Buttons Replacement: passo 5, imagem 1 %32
    • Remove a single screw from the bottom edge of the PSP.
    Pergunte ao FixBot
    Comentar
  6. PSP 300xc Trigger Buttons Replacement: passo 6, imagem 1 %32 PSP 300xc Trigger Buttons Replacement: passo 6, imagem 2 %32
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
    Pergunte ao FixBot
    Comentar
  7. PSP 300xc Trigger Buttons Replacement, LCD: passo 7, imagem 1 %32
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
    Pergunte ao FixBot
    Comentar
  8. PSP 300xc Trigger Buttons Replacement: passo 8, imagem 1 %32 PSP 300xc Trigger Buttons Replacement: passo 8, imagem 2 %32
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
    Pergunte ao FixBot
    Comentar
  9. PSP 300xc Trigger Buttons Replacement: passo 9, imagem 1 %32
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
    Pergunte ao FixBot
    Comentar
  10. PSP 300xc Trigger Buttons Replacement: passo 10, imagem 1 %32
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
    Pergunte ao FixBot
    Comentar
  11. PSP 300xc Trigger Buttons Replacement: passo 11, imagem 1 %32 PSP 300xc Trigger Buttons Replacement: passo 11, imagem 2 %32 PSP 300xc Trigger Buttons Replacement: passo 11, imagem 3 %32
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
    Pergunte ao FixBot
    Comentar
  12. PSP 300xc Trigger Buttons Replacement: passo 12, imagem 1 %32
    • Remove the LCD from the PSP 300xc.
    Pergunte ao FixBot
    Comentar
  13. PSP 300xc Trigger Buttons Replacement, Home Bar: passo 13, imagem 1 %32 PSP 300xc Trigger Buttons Replacement, Home Bar: passo 13, imagem 2 %32 PSP 300xc Trigger Buttons Replacement, Home Bar: passo 13, imagem 3 %32
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
    Pergunte ao FixBot
    Comentar
  14. PSP 300xc Trigger Buttons Replacement, Trigger Buttons: passo 14, imagem 1 %32 PSP 300xc Trigger Buttons Replacement, Trigger Buttons: passo 14, imagem 2 %32
    • Remove both trigger buttons by lifting them off the PSP 300xc.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Matthew Newsom
Membro desde: 01/05/10
42.763 Reputação
Autoria de 67 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 25
Últimos 30 dias: 86
Ao todo: 3,335
