Ir para o conteúdo principal
PSP 300x Motherboard Replacement
O que você precisa
  1. PSP 300x Motherboard Replacement, Battery: passo 1, imagem 1 %32 PSP 300x Motherboard Replacement, Battery: passo 1, imagem 2 %32 PSP 300x Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  2. PSP 300x Motherboard Replacement, Front Casing: passo 2, imagem 1 %32
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    Pergunte ao FixBot
    Comentar
  3. PSP 300x Motherboard Replacement: passo 3, imagem 1 %32 PSP 300x Motherboard Replacement: passo 3, imagem 2 %32
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
    Pergunte ao FixBot
    Comentar
  4. PSP 300x Motherboard Replacement: passo 4, imagem 1 %32
    • Next, unscrew the two screws located at the top of the PSP.
    Pergunte ao FixBot
    Comentar
  5. PSP 300x Motherboard Replacement: passo 5, imagem 1 %32
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    Pergunte ao FixBot
    Comentar
  6. PSP 300x Motherboard Replacement: passo 6, imagem 1 %32 PSP 300x Motherboard Replacement: passo 6, imagem 2 %32
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    Pergunte ao FixBot
    Comentar
  7. PSP 300x Motherboard Replacement, LCD Screen: passo 7, imagem 1 %32 PSP 300x Motherboard Replacement, LCD Screen: passo 7, imagem 2 %32
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    Pergunte ao FixBot
    Comentar
  8. PSP 300x Motherboard Replacement: passo 8, imagem 1 %32 PSP 300x Motherboard Replacement: passo 8, imagem 2 %32 PSP 300x Motherboard Replacement: passo 8, imagem 3 %32
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
    Pergunte ao FixBot
    Comentar
  9. PSP 300x Motherboard Replacement: passo 9, imagem 1 %32 PSP 300x Motherboard Replacement: passo 9, imagem 2 %32
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
    Pergunte ao FixBot
    Comentar
  10. PSP 300x Motherboard Replacement: passo 10, imagem 1 %32
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
    Pergunte ao FixBot
    Comentar
  11. PSP 300x Motherboard Replacement, Trigger Buttons: passo 11, imagem 1 %32
    • Remove the screw securing 'L' trigger to the PSP.
    Pergunte ao FixBot
    Comentar
  12. PSP 300x Motherboard Replacement: passo 12, imagem 1 %32
    • Remove the white plastic piece that holds the 'L' trigger in place.
    Pergunte ao FixBot
    Comentar
  13. PSP 300x Motherboard Replacement: passo 13, imagem 1 %32
    • Remove the 'L' trigger from the PSP.
    Pergunte ao FixBot
    Comentar
  14. PSP 300x Motherboard Replacement: passo 14, imagem 1 %32
    • Remove the screw securing the 'R' trigger.
    Pergunte ao FixBot
    Comentar
  15. PSP 300x Motherboard Replacement: passo 15, imagem 1 %32
    • Remove the white plastic piece that holds the 'R' trigger in place.
    Pergunte ao FixBot
    Comentar
  16. PSP 300x Motherboard Replacement: passo 16, imagem 1 %32
    • Remove the 'R' trigger from the PSP.
    Pergunte ao FixBot
    Comentar
  17. PSP 300x Motherboard Replacement, Analog Stick: passo 17, imagem 1 %32
    • Remove the screw from the bottom left edge of the PSP.
    Pergunte ao FixBot
    Comentar
  18. PSP 300x Motherboard Replacement: passo 18, imagem 1 %32
    • Being careful not to break the ribbon cable, use the spudger to peel the adhesive button of the the 'L' trigger off the PSP.
    Pergunte ao FixBot
    Comentar
  19. PSP 300x Motherboard Replacement: passo 19, imagem 1 %32 PSP 300x Motherboard Replacement: passo 19, imagem 2 %32
    • Using a fingernail or spudger, flip up the retaining bracket on the d-pad and 'L' trigger ribbon cable.
    • Lift the black plastic bracket along with the d-pad contact pad, disconnecting the ribbon cable as you lift.
    Pergunte ao FixBot
    Comentar
  20. PSP 300x Motherboard Replacement: passo 20, imagem 1 %32
    • Remove the cable from the connector and remove the entire black piece from the PSP.
    Pergunte ao FixBot
    Comentar
  21. PSP 300x Motherboard Replacement: passo 21, imagem 1 %32
    • Remove the screw holding the analog stick in place.
    Pergunte ao FixBot
    Comentar
  22. PSP 300x Motherboard Replacement: passo 22, imagem 1 %32 PSP 300x Motherboard Replacement: passo 22, imagem 2 %32
    • Flip up the lock on the analog sticks ribbon cable.
    • Remove the analog stick from the PSP.
    Pergunte ao FixBot
    Comentar
  23. PSP 300x Motherboard Replacement, Button Pad: passo 23, imagem 1 %32
    • After removing the LCD Screen, the Button Pad should be easy to remove.
    Pergunte ao FixBot
    Comentar
  24. PSP 300x Motherboard Replacement, Power Jack: passo 24, imagem 1 %32
    • Flip up the lock and detach the ribbon cable above the power jack.
    Pergunte ao FixBot
    Comentar
  25. PSP 300x Motherboard Replacement: passo 25, imagem 1 %32
    • Remove the screw from the power jack.
    Pergunte ao FixBot
    Comentar
  26. PSP 300x Motherboard Replacement: passo 26, imagem 1 %32
    • Carefully bend back the black tab holding the power jack in place and start pulling the jack up to release it from this clip.
    Pergunte ao FixBot
    Comentar
  27. PSP 300x Motherboard Replacement: passo 27, imagem 1 %32
    • Pull the plug connecting the power jack to the motherboard.
    • Remove the power jack.
    Pergunte ao FixBot
    Comentar
  28. PSP 300x Motherboard Replacement, Speaker: passo 28, imagem 1 %32 PSP 300x Motherboard Replacement, Speaker: passo 28, imagem 2 %32
    • Push the black tab at the bottom of the speaker to pop the speaker out of place, and remove the speaker.
    • The speaker is spring loaded, so be sure to keep an eye on it in case it starts doing flips into the air when you push the tab. Be careful not to lose or damage it!
    • Make sure the new/replacement speaker does not spring out during reassembly.
    Pergunte ao FixBot
    Comentar
  29. PSP 300x Motherboard Replacement, Motherboard: passo 29, imagem 1 %32
    • Remove the cable carefully by lifting upwards from port attached to the motherboard .
    Pergunte ao FixBot
    Comentar
  30. PSP 300x Motherboard Replacement: passo 30, imagem 1 %32
    • Flip up both of the locks and remove both cables as shown
    Pergunte ao FixBot
    Comentar
  31. PSP 300x Motherboard Replacement: passo 31, imagem 1 %32
    • Flip up the lock and remove the ribbon cable located at the bottom edge of the PSP.
    Pergunte ao FixBot
    Comentar
  32. PSP 300x Motherboard Replacement: passo 32, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the bottom left screw attached to the PSP
    Pergunte ao FixBot
    Comentar
  33. PSP 300x Motherboard Replacement, Remove Power Switch Panel: passo 33, imagem 1 %32 PSP 300x Motherboard Replacement, Remove Power Switch Panel: passo 33, imagem 2 %32 PSP 300x Motherboard Replacement, Remove Power Switch Panel: passo 33, imagem 3 %32
    • Remove the screw located at the top of the power switch panel.
    • Gently lift and remove the panel from the switch side
    Pergunte ao FixBot
    Comentar
  34. PSP 300x Motherboard Replacement: passo 34, imagem 1 %32
    • Remove the silver rim on the right side of the PSP.
    Pergunte ao FixBot
    Comentar
  35. PSP 300x Motherboard Replacement: passo 35, imagem 1 %32
    • Remove the silver rim on the left side of the PSP.
    Pergunte ao FixBot
    Comentar
  36. PSP 300x Motherboard Replacement: passo 36, imagem 1 %32 PSP 300x Motherboard Replacement: passo 36, imagem 2 %32
    • Remove the motherboard from the PSP
    Pergunte ao FixBot
    Comentar
Conclusão
18 outras pessoas executaram este guia.
mbnewsom
Membro desde: 10/28/09
3.508 Reputação
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 91
Últimos 30 dias: 685
Ao todo: 55,027
