Ir para o conteúdo principal
PSP 2000 Memory Stick Slot Replacement
O que você precisa
  1. PSP 2000  Memory Stick Slot Replacement, Battery: passo 1, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement, Battery: passo 1, imagem 2 %32 PSP 2000  Memory Stick Slot Replacement, Battery: passo 1, imagem 3 %32
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
    Pergunte ao FixBot
    Comentar
  2. PSP 2000  Memory Stick Slot Replacement, Front Casing: passo 2, imagem 1 %32
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
    Pergunte ao FixBot
    Comentar
  3. PSP 2000  Memory Stick Slot Replacement: passo 3, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement: passo 3, imagem 2 %32
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    Pergunte ao FixBot
    Comentar
  4. PSP 2000  Memory Stick Slot Replacement: passo 4, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement: passo 4, imagem 2 %32
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    Pergunte ao FixBot
    Comentar
  5. PSP 2000  Memory Stick Slot Replacement: passo 5, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement: passo 5, imagem 2 %32
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
    Pergunte ao FixBot
    Comentar
  6. PSP 2000  Memory Stick Slot Replacement, Display: passo 6, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement, Display: passo 6, imagem 2 %32 PSP 2000  Memory Stick Slot Replacement, Display: passo 6, imagem 3 %32
    • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
    • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
    Pergunte ao FixBot
    Comentar
  7. PSP 2000  Memory Stick Slot Replacement: passo 7, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement: passo 7, imagem 2 %32 PSP 2000  Memory Stick Slot Replacement: passo 7, imagem 3 %32
    • With the home bar out of the way, gently pry up the display using the opening tools.
    • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
    • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • Gently lift out the display.
    Pergunte ao FixBot
    Comentar
  8. PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: passo 8, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: passo 8, imagem 2 %32 PSP 2000  Memory Stick Slot Replacement,  Memory Stick Slot: passo 8, imagem 3 %32
    • Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
    • Slide off the left trigger along with the plastic bracket underneath.
    • Carefully pry off left trigger button using opening tools.
    • The button is adhered to the body. It can be re-adhered with hot glue after being pried-up, if necessary.
    Pergunte ao FixBot
    Comentar
  9. PSP 2000  Memory Stick Slot Replacement: passo 9, imagem 1 %32 PSP 2000  Memory Stick Slot Replacement: passo 9, imagem 2 %32
    • Use an opening tool to lift up the brown tab on the connector and remove the cable horizontally.
    • Gently remove the memory card slot by pulling it straight out.
    Pergunte ao FixBot
    Comentar
Conclusão
20 outras pessoas executaram este guia.
espinks
Membro desde: 10/18/09
3.869 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-3, Maness Fall 2009 Membro de Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Membros
Autoria de 48 guias
2Comentários do guia
Thank you, i'am Zakaria Farid from Morocoo
swat4ever2015 - Responder Compartilhar
would this work for a 2001 model?
James Ginther - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 46
Últimos 30 dias: 252
Ao todo: 32,438
