Ir para o conteúdo principal
PSP 1000 Motherboard Replacement
O que você precisa
  1. PSP 1000 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 PSP 1000 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Remove any external cables from the device and place the device face down on a flat surface.
    Pergunte ao FixBot
    Comentar
  2. PSP 1000 Motherboard Replacement: passo 2, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the battery door cover located on the left hand side.
    • Remove the battery from the device.
    Pergunte ao FixBot
    Comentar
  3. PSP 1000 Motherboard Replacement: passo 3, imagem 1 %32
    • Using a flat tool, remove the warranty sticker. Removing this sticker will expose two screws.
    Pergunte ao FixBot
    Comentar
  4. PSP 1000 Motherboard Replacement: passo 4, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 4, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 4, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove the two black 5.2 mm screws marked in red.
    • Remove the two silver 2.4 mm screws marked in orange.
    • Remove the silver 4.4 mm screw marked in yellow at the bottom of the case.
    • Remove the two black 5.4 mm screws marked in green on the back of the case.
    Pergunte ao FixBot
    Comentar
  5. PSP 1000 Motherboard Replacement: passo 5, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 5, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to gently pry the face plate off of the device.
    • Be gentle when prying the face plate as you do not want to crack or scratch it.
    Pergunte ao FixBot
    Comentar
  6. PSP 1000 Motherboard Replacement: passo 6, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 6, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 6, imagem 3 %32
    • Remove the top left and right trigger buttons by simply pulling them out.
    Pergunte ao FixBot
    Comentar
  7. PSP 1000 Motherboard Replacement: passo 7, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 7, imagem 2 %32
    • Using a plastic opening tool, lift the left side of the bottom circuit that includes the home, start, pause, and volume buttons.
    Pergunte ao FixBot
    Comentar
  8. PSP 1000 Motherboard Replacement: passo 8, imagem 1 %32
    • Disconnect the zero-insertion force (ZIF) connector by unlocking the locking tab with a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  9. PSP 1000 Motherboard Replacement: passo 9, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 9, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 9, imagem 3 %32
    • Using a plastic opening tool, lift the LCD screen from in between the metal brackets.
    • Start at the bottom of the screen for an efficient removal.
    • Be very careful as the screen is very fragile.
    Pergunte ao FixBot
    Comentar
  10. PSP 1000 Motherboard Replacement: passo 10, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 10, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 10, imagem 3 %32
    • Use the plastic opening tool to unlock all the ribbon cables attached from the LCD screen to the motherboard.
    Pergunte ao FixBot
    Comentar
  11. PSP 1000 Motherboard Replacement: passo 11, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 11, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 11, imagem 3 %32
    • Using the Phillips #00 screwdriver, remove the two silver 4.2mm screws marked in red.
    • Remove the three silver 3mm screws marked in orange.
    • Remove the black 4.2mm screw marked in yellow.
    Pergunte ao FixBot
    Comentar
  12. PSP 1000 Motherboard Replacement: passo 12, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 12, imagem 2 %32
    • Once all screws are removed, gently lift the metal cage from the bottom.
    • If there is resistance, slide the open button on top of the device as it may be latched to the cage.
    Pergunte ao FixBot
    Comentar
  13. PSP 1000 Motherboard Replacement, Note the conductive piece: passo 13, imagem 1 %32 PSP 1000 Motherboard Replacement, Note the conductive piece: passo 13, imagem 2 %32 PSP 1000 Motherboard Replacement, Note the conductive piece: passo 13, imagem 3 %32
    • The midframe has a rectangular conductive piece that can fall out and be lost. Without it, the joystick won't work. Make sure to reinsert it so that the contacts on the conductive piece touches the pads.
    Pergunte ao FixBot
    Comentar
  14. PSP 1000 Motherboard Replacement: passo 14, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 14, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 14, imagem 3 %32
    • Remove the single 4.4mm screw that holds the D-Pad in place using the Phillips #00 screwdriver.
    • Underneath the D-Pad, unlock the ZIF connector holding the ribbon cable in place using the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  15. PSP 1000 Motherboard Replacement: passo 15, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 15, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 15, imagem 3 %32
    • Using a plastic opening tool, unlock the small black clip that is located underneath the circuit board.
    Pergunte ao FixBot
    Comentar
  16. PSP 1000 Motherboard Replacement: passo 16, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 16, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 16, imagem 3 %32
    • Using a plastic opening tool, remove the steel bracket under the right trigger.
    Pergunte ao FixBot
    Comentar
  17. PSP 1000 Motherboard Replacement: passo 17, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 17, imagem 2 %32
    • Use the plastic opening tool to unlock all of the ZIF connectors and disconnect all cables from the motherboard.
    Pergunte ao FixBot
    Comentar
  18. PSP 1000 Motherboard Replacement: passo 18, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 18, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 18, imagem 3 %32
    • Using a plastic opening tool, unclip the cable from the circuit and begin to remove any tape securing any cables.
    • Remove the single 1.5 mm screw on the bottom right of the power input using the Phillips #00 screwdriver to remove the cable.
    Pergunte ao FixBot
    Comentar
  19. PSP 1000 Motherboard Replacement: passo 19, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 19, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 19, imagem 3 %32
    • Above the charging input cable is the wireless antenna. Gently lift and place the wireless antenna on the left-hand side as it cannot be completely removed.
    Pergunte ao FixBot
    Comentar
  20. PSP 1000 Motherboard Replacement: passo 20, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 20, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 20, imagem 3 %32
    • Remove the speaker cables highlighted on the bottom middle by removing any tape.
    • Using a flat tool unclip the cables from the motherboard along with the ribbon cable on the right.
    Pergunte ao FixBot
    Comentar
  21. PSP 1000 Motherboard Replacement: passo 21, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 21, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 21, imagem 3 %32
    • Using your fingers or a plastic opening tool, slide the UMD drive ribbon cable from the lock to release it.
    Pergunte ao FixBot
    Comentar
  22. PSP 1000 Motherboard Replacement: passo 22, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 22, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 22, imagem 3 %32
    • Using the Phillips #00 screwdriver, remove the single 4.4 mm screw located on the top right of the motherboard.
    Pergunte ao FixBot
    Comentar
  23. PSP 1000 Motherboard Replacement: passo 23, imagem 1 %32 PSP 1000 Motherboard Replacement: passo 23, imagem 2 %32 PSP 1000 Motherboard Replacement: passo 23, imagem 3 %32
    • Gently lift the motherboard up and away to remove it from the device.
    • Carefully and slowly remove the motherboard as you do not want to damage anything caught onto the board.
    Pergunte ao FixBot
    Comentar
Conclusão
10 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 138
Últimos 30 dias: 657
Ao todo: 23,078
