Introdução
Is your controller not vibrating no matter what you try? Does only one side of your controller vibrate and not the other? It might be time to replace the vibration motor(s), otherwise known as rumble motors, in your controller.
O que você precisa
Remove the two 10 mm Phillips #1 screws that secure each of the handle grips.
Pull off the handle grips.
Use blunt tweezers to pull the white battery motherboard connector directly out of its port.
Gently peel the battery off of the motherboard.
Prop the motherboard up with a non-flammable material.
Carefully desolder each of the vibration motor motherboard connections.
Remove the vibration motors.
Uma outra pessoa concluiu este guia.
