Ir para o conteúdo principal
PSKONTORORA LBER-P4-05 Vibration Motor Replacement
O que você precisa
  1. PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Rear Case: passo 1, imagem 1 %32 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Rear Case: passo 1, imagem 2 %32 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Rear Case: passo 1, imagem 3 %32
    • Remove the two 10 mm Phillips #1 screws that secure each of the handle grips.
    • Pull off the handle grips.
  2. PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 2, imagem 1 %32 PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 2, imagem 2 %32 PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 2, imagem 3 %32
    • Remove the four 9 mm Phillips #1 screws that secure the rear case.
    • Lift off the rear case from the controller.
  3. PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Battery: passo 3, imagem 1 %32 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Battery: passo 3, imagem 2 %32 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Battery: passo 3, imagem 3 %32
    • Use blunt tweezers to pull the white battery motherboard connector directly out of its port.
    • Gently peel the battery off of the motherboard.
    • Be sure not to bend or puncture the battery during removal.
  4. PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Joystick Covers: passo 4, imagem 1 %32
    • Remove the two 7 mm Phillips #1 screws that secure the motherboard.
  5. PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 5, imagem 1 %32 PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 5, imagem 2 %32
    • Flip up the black ZIF locking flap that secures the touchpad ribbon cable on the top-right edge of the motherboard.
    • Use tweezers or your fingers to gently disconnect the touchpad ribbon cable.
    • Lift the motherboard up and out.
  6. PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 6, imagem 1 %32 PSKONTORORA LBER-P4-05 Vibration Motor Replacement: passo 6, imagem 2 %32
    • Use your fingers to pull the joystick covers directly up and off the modules.
    • Clean or replace the joystick covers as necessary.
  7. PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Vibration Motor: passo 7, imagem 1 %32 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Vibration Motor: passo 7, imagem 2 %32 PSKONTORORA LBER-P4-05 Vibration Motor Replacement, Vibration Motor: passo 7, imagem 3 %32
    • Prop the motherboard up with a non-flammable material.
    • Carefully desolder each of the vibration motor motherboard connections.
    • Take note of which wires belong where.
    • Be sure to solder in a well-ventilated area and take appropriate safety precautions.
    • Remove the vibration motors.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 71
