Ir para o conteúdo principal
PDP Rematch Faceplate Replacement
O que você precisa
  1. PDP Rematch Faceplate Replacement, Faceplate: passo 1, imagem 1 %32 PDP Rematch Faceplate Replacement, Faceplate: passo 1, imagem 2 %32
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    Pergunte ao FixBot
    Comentar
  2. PDP Rematch Faceplate Replacement: passo 2, imagem 1 %32 PDP Rematch Faceplate Replacement: passo 2, imagem 2 %32
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    Pergunte ao FixBot
    Comentar
  3. PDP Rematch Faceplate Replacement: passo 3, imagem 1 %32 PDP Rematch Faceplate Replacement: passo 3, imagem 2 %32
    • Gently lift off the hard cover with your hand; it should not need much force.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 11
Últimos 30 dias: 57
Ao todo: 816
