Ir para o conteúdo principal
PDP Rematch Cable Replacement
O que você precisa
    1. PDP Rematch Cable Replacement, Faceplate: passo 1, imagem 1 %32 PDP Rematch Cable Replacement, Faceplate: passo 1, imagem 2 %32
      • Grip one side of the controller firmly.
      • Insert an opening pick into the crease between the faceplate and the body of the controller.
      • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
      • Carefully move the picks along the controller's crease line until you hear a popping sound.
      • Gently lift off the faceplate by hand.
      Pergunte ao FixBot
      Comentar
    2. PDP Rematch Cable Replacement: passo 2, imagem 1 %32 PDP Rematch Cable Replacement: passo 2, imagem 2 %32
      • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
      • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
      Pergunte ao FixBot
      Comentar
    3. PDP Rematch Cable Replacement: passo 3, imagem 1 %32 PDP Rematch Cable Replacement: passo 3, imagem 2 %32
      • Gently lift off the hard cover with your hand; it should not need much force.
      Pergunte ao FixBot
      Comentar
    1. PDP Rematch Cable Replacement, Cable: passo 4, imagem 1 %32
      • Remove the two screws on the motherboard with a JIS #000 screwdriver.
      • Gently flip the motherboard up to see the other side.
      Pergunte ao FixBot
      Comentar
    2. PDP Rematch Cable Replacement: passo 5, imagem 1 %32
      • Remove the cable from its plug on the motherboard.
      • This should give you room to carefully detach the Male Pitch Terminal Pin Header from the Female Terminal Pin.
      Pergunte ao FixBot
      Comentar
    3. PDP Rematch Cable Replacement: passo 6, imagem 1 %32
      • Take the new cable and thread it through the slot. The terminal block should fit loosely into the slot.
      • Then, insert the Male Pitch Terminal Pin into the Female Terminal Pin.
      Pergunte ao FixBot
      Comentar
Conclusão
Sydney Foster
Membro desde: 01/30/24
97 Reputação
Autoria de 1 guia
1Comentário do guia
Where do I buy the replacement cord from?
Keithy Bruce - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 44
Ao todo: 696
