Ir para o conteúdo principal
PDP Rematch Advanced Trigger Springs Replacement
O que você precisa
    1. PDP Rematch Advanced Trigger Springs Replacement, Trigger Springs: passo 1, imagem 1 %32 PDP Rematch Advanced Trigger Springs Replacement, Trigger Springs: passo 1, imagem 2 %32
      • Orient the controller so the back side is facing you.
      • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
      Pergunte ao FixBot
      Comentar
    2. PDP Rematch Advanced Trigger Springs Replacement: passo 2, imagem 1 %32 PDP Rematch Advanced Trigger Springs Replacement: passo 2, imagem 2 %32 PDP Rematch Advanced Trigger Springs Replacement: passo 2, imagem 3 %32
      • Pull apart the controller's front and back shells with moderate force.
      • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
      Pergunte ao FixBot
      Comentar
    3. PDP Rematch Advanced Trigger Springs Replacement: passo 3, imagem 1 %32 PDP Rematch Advanced Trigger Springs Replacement: passo 3, imagem 2 %32
      • Twist the thumbstick to remove it from the motherboard.
      Pergunte ao FixBot
      Comentar
    4. PDP Rematch Advanced Trigger Springs Replacement: passo 4, imagem 1 %32 PDP Rematch Advanced Trigger Springs Replacement: passo 4, imagem 2 %32 PDP Rematch Advanced Trigger Springs Replacement: passo 4, imagem 3 %32
      • Use a Phillips #000 screwdriver to remove the two 5 mm screws that secure the motherboard.
      • Remove the motherboard from the back shell using moderate force.
      Pergunte ao FixBot
      Comentar
    5. PDP Rematch Advanced Trigger Springs Replacement: passo 5, imagem 1 %32 PDP Rematch Advanced Trigger Springs Replacement: passo 5, imagem 2 %32 PDP Rematch Advanced Trigger Springs Replacement: passo 5, imagem 3 %32
      • Punch out the metal pin holding in the trigger and the trigger spring. Repeat for both triggers.
      • Remove the trigger and the trigger springs.
      • Using a punch or a small tool allows pin removal to be easier.
      Pergunte ao FixBot
      Comentar
Conclusão
Jacob Thomas Wolgamott
Membro desde: 09/23/24
121 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 41
Ao todo: 648
