Ir para o conteúdo principal
PDP Rematch Advanced Shoulder Buttons Replacement
O que você precisa
    1. PDP Rematch Advanced Shoulder Buttons Replacement, Front Housing Shell: passo 1, imagem 1 %32 PDP Rematch Advanced Shoulder Buttons Replacement, Front Housing Shell: passo 1, imagem 2 %32 PDP Rematch Advanced Shoulder Buttons Replacement, Front Housing Shell: passo 1, imagem 3 %32
      • Orient the controller so the back side is facing you.
      • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
      Pergunte ao FixBot
      Comentar
    2. PDP Rematch Advanced Shoulder Buttons Replacement: passo 2, imagem 1 %32 PDP Rematch Advanced Shoulder Buttons Replacement: passo 2, imagem 2 %32 PDP Rematch Advanced Shoulder Buttons Replacement: passo 2, imagem 3 %32
      • Pull apart the controller's front and back shells with moderate force.
      • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
      Pergunte ao FixBot
      Comentar
    3. PDP Rematch Advanced Shoulder Buttons Replacement: passo 3, imagem 1 %32 PDP Rematch Advanced Shoulder Buttons Replacement: passo 3, imagem 2 %32 PDP Rematch Advanced Shoulder Buttons Replacement: passo 3, imagem 3 %32
      • Peel the rubber piece off the back of the face buttons.
      Pergunte ao FixBot
      Comentar
    4. PDP Rematch Advanced Shoulder Buttons Replacement: passo 4, imagem 1 %32 PDP Rematch Advanced Shoulder Buttons Replacement: passo 4, imagem 2 %32 PDP Rematch Advanced Shoulder Buttons Replacement: passo 4, imagem 3 %32
      • Push all the face buttons out from the front of the shell.
      Pergunte ao FixBot
      Comentar
    5. PDP Rematch Advanced Shoulder Buttons Replacement: passo 5, imagem 1 %32 PDP Rematch Advanced Shoulder Buttons Replacement: passo 5, imagem 2 %32 PDP Rematch Advanced Shoulder Buttons Replacement: passo 5, imagem 3 %32
      • Put two fingers behind the bumpers and push upwards to remove them.
      Pergunte ao FixBot
      Comentar
    1. PDP Rematch Advanced Shoulder Buttons Replacement, Shoulder Buttons: passo 6, imagem 1 %32 PDP Rematch Advanced Shoulder Buttons Replacement, Shoulder Buttons: passo 6, imagem 2 %32 PDP Rematch Advanced Shoulder Buttons Replacement, Shoulder Buttons: passo 6, imagem 3 %32
      • Push down on the trigger's long paddle.
      • Carefully twist the bumper out to remove it from the bumper frame.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 35
Ao todo: 749
