Ir para o conteúdo principal
PDP Rematch Advanced Front Housing Shell Replacement
O que você precisa
  1. PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: passo 1, imagem 1 %32 PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: passo 1, imagem 2 %32 PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: passo 1, imagem 3 %32
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    Pergunte ao FixBot
    Comentar
  2. PDP Rematch Advanced Front Housing Shell Replacement: passo 2, imagem 1 %32 PDP Rematch Advanced Front Housing Shell Replacement: passo 2, imagem 2 %32 PDP Rematch Advanced Front Housing Shell Replacement: passo 2, imagem 3 %32
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    Pergunte ao FixBot
    Comentar
  3. PDP Rematch Advanced Front Housing Shell Replacement: passo 3, imagem 1 %32 PDP Rematch Advanced Front Housing Shell Replacement: passo 3, imagem 2 %32 PDP Rematch Advanced Front Housing Shell Replacement: passo 3, imagem 3 %32
    • Peel the rubber piece off the back of the face buttons.
    Pergunte ao FixBot
    Comentar
  4. PDP Rematch Advanced Front Housing Shell Replacement: passo 4, imagem 1 %32 PDP Rematch Advanced Front Housing Shell Replacement: passo 4, imagem 2 %32 PDP Rematch Advanced Front Housing Shell Replacement: passo 4, imagem 3 %32
    • Push all the face buttons out from the front of the shell.
    Pergunte ao FixBot
    Comentar
  5. PDP Rematch Advanced Front Housing Shell Replacement: passo 5, imagem 1 %32 PDP Rematch Advanced Front Housing Shell Replacement: passo 5, imagem 2 %32 PDP Rematch Advanced Front Housing Shell Replacement: passo 5, imagem 3 %32
    • Put two fingers behind the bumpers and push upwards to remove them.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Collin Lawe
Membro desde: 10/02/23
462 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 35
Ao todo: 472
