Ir para o conteúdo principal
PDP Rematch Advanced Back Buttons Replacement
O que você precisa
  1. PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: passo 1, imagem 1 %32 PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: passo 1, imagem 2 %32 PDP Rematch Advanced Back Buttons Replacement, Joystick Cover: passo 1, imagem 3 %32
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    Pergunte ao FixBot
    Comentar
  2. PDP Rematch Advanced Back Buttons Replacement: passo 2, imagem 1 %32 PDP Rematch Advanced Back Buttons Replacement: passo 2, imagem 2 %32 PDP Rematch Advanced Back Buttons Replacement: passo 2, imagem 3 %32
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    Pergunte ao FixBot
    Comentar
  3. PDP Rematch Advanced Back Buttons Replacement: passo 3, imagem 1 %32 PDP Rematch Advanced Back Buttons Replacement: passo 3, imagem 2 %32
    • Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
    Pergunte ao FixBot
    Comentar
  4. PDP Rematch Advanced Back Buttons Replacement, Back Shell: passo 4, imagem 1 %32 PDP Rematch Advanced Back Buttons Replacement, Back Shell: passo 4, imagem 2 %32
    • Grab the motor and pull away from the back shell. Repeat for both motors.
    Pergunte ao FixBot
    Comentar
  5. PDP Rematch Advanced Back Buttons Replacement: passo 5, imagem 1 %32 PDP Rematch Advanced Back Buttons Replacement: passo 5, imagem 2 %32
    • Use a Phillips #00 Screwdriver to remove the two 5mm screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. PDP Rematch Advanced Back Buttons Replacement: passo 6, imagem 1 %32 PDP Rematch Advanced Back Buttons Replacement: passo 6, imagem 2 %32 PDP Rematch Advanced Back Buttons Replacement: passo 6, imagem 3 %32
    • Remove the motherboard from the back shell using moderate force.
    Pergunte ao FixBot
    Comentar
  7. PDP Rematch Advanced Back Buttons Replacement, Back Buttons: passo 7, imagem 1 %32 PDP Rematch Advanced Back Buttons Replacement, Back Buttons: passo 7, imagem 2 %32
    • Use a Phillips #00 to remove the two 5mm screws from the back buttons.
    Pergunte ao FixBot
    Comentar
  8. PDP Rematch Advanced Back Buttons Replacement: passo 8, imagem 1 %32 PDP Rematch Advanced Back Buttons Replacement: passo 8, imagem 2 %32 PDP Rematch Advanced Back Buttons Replacement: passo 8, imagem 3 %32
    • Lift the back button, and then pull it out through the back shell. Do this for both back buttons.
    Pergunte ao FixBot
    Comentar
Conclusão
Collin Lawe
Membro desde: 10/02/23
462 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 23
Ao todo: 659
