Ir para o conteúdo principal
PDP Afterglow Fener LED Replacement
O que você precisa
  1. PDP Afterglow Fener LED Replacement, LED: passo 1, imagem 1 %32 PDP Afterglow Fener LED Replacement, LED: passo 1, imagem 2 %32 PDP Afterglow Fener LED Replacement, LED: passo 1, imagem 3 %32
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide here.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
    • This is a picture of what your headset looks like now that you have done the first two steps and have removed the part that you unscrewed.
    Pergunte ao FixBot
    Comentar
  2. PDP Afterglow Fener LED Replacement: passo 2, imagem 1 %32 PDP Afterglow Fener LED Replacement: passo 2, imagem 2 %32
    • First remove the battery from the headset, for instructions on how to do this correctly go here
    • Now take your J000 screwdriver and unscrew the screws that have a red circle around them.
    • Now remove the circuit board from the headset and flip it to the other side to be able to see the light/LED.
    Pergunte ao FixBot
    Comentar
  3. PDP Afterglow Fener LED Replacement: passo 3, imagem 1 %32 PDP Afterglow Fener LED Replacement: passo 3, imagem 2 %32 PDP Afterglow Fener LED Replacement: passo 3, imagem 3 %32
    • Take your helping hand with alligator clips and put the printed circuit board on it.
    • This picture is a close up of the LED with the highlighted areas you need to unsoldered.
    • Now take your soldering iron and unsolder those four highlighted areas.
    • Your LED should come loose and you can now put on your new LED.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 1,084
