Introdução
The process of removing covers and simple internal components requires minimal technical experience.
O que você precisa
Unplug the device from any energy sources.
Lift the top cover of the scanner.
Use a plastic opening tool to remove the plastic frame surrounding the glass.
To reassemble, simply follow the steps in reverse order.
9 outras pessoas executaram este guia.
3Comentários do guia
Excellent helpful easy to follow instructions. Thanks.
In step 7, removal of the Touch Pad, I was not able to locate the release clip. Feeling around, what I thought was the latch was a ribbon cable that I distorted but didn't destroy. The top came off without the Touch Pad removal. Once the top was off, I located a latch on the back right of the Touch Pad, but once released, it didn't help to free up the Touch Pad. I couldn't get the Touch Pad off.
Really great to have these instructions, just what I needed so that I could open up my printer.
Thanks!
Replying to Ken: I couldn't get it out either. I carried on to get the top cover off without removing it. I think I may have seen a screw in behind the touch pad / display? Certainly a clip, at least.
