Ir para o conteúdo principal
Oster 6329 Lever Catch Spring Replacement
O que você precisa
    1. Oster 6329 Lever Catch Spring Replacement, Outer Shell Removal: passo 1, imagem 1 %32 Oster 6329 Lever Catch Spring Replacement, Outer Shell Removal: passo 1, imagem 2 %32
      • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
      Pergunte ao FixBot
      Comentar
    2. Oster 6329 Lever Catch Spring Replacement: passo 2, imagem 1 %32
      • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
      Pergunte ao FixBot
      Comentar
    3. Oster 6329 Lever Catch Spring Replacement: passo 3, imagem 1 %32
      • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
      • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
      Pergunte ao FixBot
      Comentar
    4. Oster 6329 Lever Catch Spring Replacement: passo 4, imagem 1 %32 Oster 6329 Lever Catch Spring Replacement: passo 4, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
      Pergunte ao FixBot
      Comentar
    5. Oster 6329 Lever Catch Spring Replacement: passo 5, imagem 1 %32 Oster 6329 Lever Catch Spring Replacement: passo 5, imagem 2 %32
      • Lift the top outer metal shell.
      • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
      Pergunte ao FixBot
      Comentar
    1. Oster 6329 Lever Catch Spring Replacement, Lever Catch Spring: passo 6, imagem 1 %32
      • Insert the tweezers between the spring and the bottom of the lever to release the spring.
      Pergunte ao FixBot
      Comentar
    2. Oster 6329 Lever Catch Spring Replacement: passo 7, imagem 1 %32 Oster 6329 Lever Catch Spring Replacement: passo 7, imagem 2 %32
      • Remove spring from the bottom of the lever.
      • The spring should only be connected to the top of the toaster after this is complete.
      Pergunte ao FixBot
      Comentar
    3. Oster 6329 Lever Catch Spring Replacement: passo 8, imagem 1 %32
      • Insert the tweezers between the two metal flaps located at the top of the toaster.
      • Hold the spring and turn it sideways to lay it flat along the top of the toaster.
      • Pry the spring from the top of the toaster.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 13-15, Regan Winter 2014 Membro de Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
5 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 37
Ao todo: 1,671
