Ir para o conteúdo principal
Oster 3905 Retractable Cord Replacement
O que você precisa
    1. Oster 3905 Retractable Cord Replacement, Slot Levers: passo 1, imagem 1 %32
      • Firmly grip your hand around the slot lever.
      Pergunte ao FixBot
      Comentar
    2. Oster 3905 Retractable Cord Replacement: passo 2, imagem 1 %32
      • Stabilize the toaster by placing your hand on top.
      Pergunte ao FixBot
      Comentar
    3. Oster 3905 Retractable Cord Replacement: passo 3, imagem 1 %32 Oster 3905 Retractable Cord Replacement: passo 3, imagem 2 %32
      • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
      Pergunte ao FixBot
      Comentar
    4. Oster 3905 Retractable Cord Replacement: passo 4, imagem 1 %32
      • Both slot levers can be removed.
      Pergunte ao FixBot
      Comentar
    1. Oster 3905 Retractable Cord Replacement, Outer Shell: passo 5, imagem 1 %32
      • Place the toaster upside down so the bottom is facing the ceiling.
      Pergunte ao FixBot
      Comentar
    2. Oster 3905 Retractable Cord Replacement: passo 6, imagem 1 %32 Oster 3905 Retractable Cord Replacement: passo 6, imagem 2 %32
      • Take off both rubber feet using a small metal spudger.
      • Wedge a spudger under the feet and pull up to pop off.
      Pergunte ao FixBot
      Comentar
    3. Oster 3905 Retractable Cord Replacement: passo 7, imagem 1 %32
      • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
      • There are two screws under the rubber feet.
      Pergunte ao FixBot
      Comentar
    4. Oster 3905 Retractable Cord Replacement: passo 8, imagem 1 %32
      • Place the toaster right side up.
      Pergunte ao FixBot
      Comentar
    5. Oster 3905 Retractable Cord Replacement: passo 9, imagem 1 %32 Oster 3905 Retractable Cord Replacement: passo 9, imagem 2 %32
      • Grab the outer shell firmly and pull up towards the face of the toaster.
      Pergunte ao FixBot
      Comentar
    6. Oster 3905 Retractable Cord Replacement: passo 10, imagem 1 %32
      • For this part, you might need to wiggle the toaster to get the outer shell off.
      • The shell will not completely come off until the motherboard is removed in the next step.
      Pergunte ao FixBot
      Comentar
    7. Oster 3905 Retractable Cord Replacement: passo 11, imagem 1 %32 Oster 3905 Retractable Cord Replacement: passo 11, imagem 2 %32 Oster 3905 Retractable Cord Replacement: passo 11, imagem 3 %32
      • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
      Pergunte ao FixBot
      Comentar
    8. Oster 3905 Retractable Cord Replacement: passo 12, imagem 1 %32 Oster 3905 Retractable Cord Replacement: passo 12, imagem 2 %32
      • Take out the grey “cancel” and “bagel” buttons from the shell.
      Pergunte ao FixBot
      Comentar
    1. Oster 3905 Retractable Cord Replacement, Retractable Cord: passo 13, imagem 1 %32
      • Rotate the toaster so that the back is facing towards you.
      Pergunte ao FixBot
      Comentar
    2. Oster 3905 Retractable Cord Replacement: passo 14, imagem 1 %32 Oster 3905 Retractable Cord Replacement: passo 14, imagem 2 %32
      • Use the PH#1 bit to remove one 8mm screw located above the wire on the casing.
      • Then use the same screw bit to remove two 10mm screws found at the bottom.
      Pergunte ao FixBot
      Comentar
    3. Oster 3905 Retractable Cord Replacement: passo 15, imagem 1 %32 Oster 3905 Retractable Cord Replacement: passo 15, imagem 2 %32
      • Using the metal spudger, pry next to the black clip found at the base of the toaster and the casing.
      • Push down to separate the casing from the toaster.
      Pergunte ao FixBot
      Comentar
    4. Oster 3905 Retractable Cord Replacement: passo 16, imagem 1 %32 Oster 3905 Retractable Cord Replacement: passo 16, imagem 2 %32
      • Gently tilt the casing towards the toaster as you pull up from the base.
      Pergunte ao FixBot
      Comentar
    5. Oster 3905 Retractable Cord Replacement: passo 17, imagem 1 %32
      • Use the PH#1 bit to remove the three 8mm screws located on the back side of the casing.
      Pergunte ao FixBot
      Comentar
    6. Oster 3905 Retractable Cord Replacement: passo 18, imagem 1 %32 Oster 3905 Retractable Cord Replacement: passo 18, imagem 2 %32
      • When opening the casing a metal spring may suddenly pop out.
      • Use the metal spudger to pry open the two halves of the casing.
      • If you are having some trouble only using the metal spudger do not be afraid of using your fingers to pry the casing apart.
      Pergunte ao FixBot
      Comentar
    7. Oster 3905 Retractable Cord Replacement: passo 19, imagem 1 %32 Oster 3905 Retractable Cord Replacement: passo 19, imagem 2 %32 Oster 3905 Retractable Cord Replacement: passo 19, imagem 3 %32
      • Carefully remove the spool keeping your fingers on either side of the casing.
      • Tape down the metal spring to keep it from unraveling out of place.
      Pergunte ao FixBot
      Comentar
    8. Oster 3905 Retractable Cord Replacement: passo 20, imagem 1 %32 Oster 3905 Retractable Cord Replacement: passo 20, imagem 2 %32 Oster 3905 Retractable Cord Replacement: passo 20, imagem 3 %32
      • Carefully unwind the power cord from the spool.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Adam Dierkes
Membro desde: 09/12/16
140 Reputação
Autoria de 1 guia
Equipe
CSU Fullerton, Team 2-1, Bruce Fall 2016 Membro de CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
5 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 36
Ao todo: 934
