Ir para o conteúdo principal
Oster 3905 Lever Spring Replacement
O que você precisa
    1. Oster 3905 Lever Spring Replacement, Slot Levers: passo 1, imagem 1 %32
      • Firmly grip your hand around the slot lever.
      Pergunte ao FixBot
      Comentar
    2. Oster 3905 Lever Spring Replacement: passo 2, imagem 1 %32
      • Stabilize the toaster by placing your hand on top.
      Pergunte ao FixBot
      Comentar
    3. Oster 3905 Lever Spring Replacement: passo 3, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 3, imagem 2 %32
      • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
      Pergunte ao FixBot
      Comentar
    4. Oster 3905 Lever Spring Replacement: passo 4, imagem 1 %32
      • Both slot levers can be removed.
      Pergunte ao FixBot
      Comentar
    1. Oster 3905 Lever Spring Replacement, Outer Shell: passo 5, imagem 1 %32
      • Place the toaster upside down so the bottom is facing the ceiling.
      Pergunte ao FixBot
      Comentar
    2. Oster 3905 Lever Spring Replacement: passo 6, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 6, imagem 2 %32
      • Take off both rubber feet using a small metal spudger.
      • Wedge a spudger under the feet and pull up to pop off.
      Pergunte ao FixBot
      Comentar
    3. Oster 3905 Lever Spring Replacement: passo 7, imagem 1 %32
      • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
      • There are two screws under the rubber feet.
      Pergunte ao FixBot
      Comentar
    4. Oster 3905 Lever Spring Replacement: passo 8, imagem 1 %32
      • Place the toaster right side up.
      Pergunte ao FixBot
      Comentar
    5. Oster 3905 Lever Spring Replacement: passo 9, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 9, imagem 2 %32
      • Grab the outer shell firmly and pull up towards the face of the toaster.
      Pergunte ao FixBot
      Comentar
    6. Oster 3905 Lever Spring Replacement: passo 10, imagem 1 %32
      • For this part, you might need to wiggle the toaster to get the outer shell off.
      • The shell will not completely come off until the motherboard is removed in the next step.
      Pergunte ao FixBot
      Comentar
    7. Oster 3905 Lever Spring Replacement: passo 11, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 11, imagem 2 %32 Oster 3905 Lever Spring Replacement: passo 11, imagem 3 %32
      • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
      Pergunte ao FixBot
      Comentar
    8. Oster 3905 Lever Spring Replacement: passo 12, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 12, imagem 2 %32
      • Take out the grey “cancel” and “bagel” buttons from the shell.
      Pergunte ao FixBot
      Comentar
    1. Oster 3905 Lever Spring Replacement, Lever Spring: passo 13, imagem 1 %32 Oster 3905 Lever Spring Replacement, Lever Spring: passo 13, imagem 2 %32
      • Use the plastic opening tool to remove the top metal panel by prying the 4 top metal tabs upwards. They will be able to slide through the openings and be pulled upwards.
      Pergunte ao FixBot
      Comentar
    2. Oster 3905 Lever Spring Replacement: passo 14, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 14, imagem 2 %32
      • Once the top metal panel is unhooked, lift and let it hang off the side of the toaster.
      Pergunte ao FixBot
      Comentar
    3. Oster 3905 Lever Spring Replacement: passo 15, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 15, imagem 2 %32 Oster 3905 Lever Spring Replacement: passo 15, imagem 3 %32
      • Use a metal spudger to pry the 8 tabs upwards along the metal that separates the two slots.
      • Pull the metal spacer upwards to release from the toaster.
      Pergunte ao FixBot
      Comentar
    4. Oster 3905 Lever Spring Replacement: passo 16, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 16, imagem 2 %32
      • Remove the spring wrapped around a metal rod at the front of the toaster, located behind the white plastic lever holder.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
CSU Fullerton, Team 2-1, Bruce Fall 2016 Membro de CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
5 Membros
Autoria de 18 guias
2Comentários do guia
Where's the fix?
D Unger - Responder Compartilhar
Yeah. You just remove the spring? And then what? Surely removing the spring is not the fix.
kryshu - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 3,464
