Ir para o conteúdo principal
Oster 16-Speed Blender Container Replacement
    1. Oster 16-Speed Blender Container Replacement, Container: passo 1, imagem 1 %32 Oster 16-Speed Blender Container Replacement, Container: passo 1, imagem 2 %32
      • First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
      Pergunte ao FixBot
      Comentar
    2. Oster 16-Speed Blender Container Replacement: passo 2, imagem 1 %32 Oster 16-Speed Blender Container Replacement: passo 2, imagem 2 %32
      • Next, remove the lid from the Blender Container.
      Pergunte ao FixBot
      Comentar
    3. Oster 16-Speed Blender Container Replacement: passo 3, imagem 1 %32 Oster 16-Speed Blender Container Replacement: passo 3, imagem 2 %32
      • Flip the container on its side so that the bottom faces you.
      • Now rotate the bottom counter-clockwise to remove it from the container.
      Pergunte ao FixBot
      Comentar
    4. Oster 16-Speed Blender Container Replacement: passo 4, imagem 1 %32 Oster 16-Speed Blender Container Replacement: passo 4, imagem 2 %32
      • Now you will see the bottom of the blender blades once the bottom piece is removed
      • Carefully remove the blender blades from the container seeing as they are very sharp and can cut you.
      Pergunte ao FixBot
      Comentar
    5. Oster 16-Speed Blender Container Replacement: passo 5, imagem 1 %32
      • Now your container is separated.
      Pergunte ao FixBot
      Comentar
Conclusão
With your container separated, it can now be replaced. To reassemble your device, follow these instructions in reverse order.
Dana
Membro desde: 04/14/14
881 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-37, Maness Spring 2014 Membro de Cal Poly, Team 12-37, Maness Spring 2014
CPSU-MANESS-S14S12G37
4 Membros
Autoria de 27 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 34
Ao todo: 1,459
