Ir para o conteúdo principal
Osmo Mobile Bluetooth Module Replacement
O que você precisa
  1. Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: passo 1, imagem 1 %32 Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: passo 1, imagem 2 %32
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
    Pergunte ao FixBot
    Comentar
  2. Osmo Mobile Bluetooth Module Replacement: passo 2, imagem 1 %32 Osmo Mobile Bluetooth Module Replacement: passo 2, imagem 2 %32
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
    Pergunte ao FixBot
    Comentar
  3. Osmo Mobile Bluetooth Module Replacement: passo 3, imagem 1 %32
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Osmo Mobile Bluetooth Module Replacement: passo 4, imagem 1 %32 Osmo Mobile Bluetooth Module Replacement: passo 4, imagem 2 %32
    • Remove joystick by gently pulling away from handle
    Pergunte ao FixBot
    Comentar
  5. Osmo Mobile Bluetooth Module Replacement: passo 5, imagem 1 %32 Osmo Mobile Bluetooth Module Replacement: passo 5, imagem 2 %32 Osmo Mobile Bluetooth Module Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
    Pergunte ao FixBot
    Comentar
  6. Osmo Mobile Bluetooth Module Replacement: passo 6, imagem 1 %32 Osmo Mobile Bluetooth Module Replacement: passo 6, imagem 2 %32 Osmo Mobile Bluetooth Module Replacement: passo 6, imagem 3 %32
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
    Pergunte ao FixBot
    Comentar
  7. Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: passo 7, imagem 1 %32 Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: passo 7, imagem 2 %32 Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: passo 7, imagem 3 %32
    • Locate and remove the black screw found at the base of the grey mounting plate.
    • Remove the grey face plate.
    Pergunte ao FixBot
    Comentar
  8. Osmo Mobile Bluetooth Module Replacement: passo 8, imagem 1 %32 Osmo Mobile Bluetooth Module Replacement: passo 8, imagem 2 %32
    • Open the battery hatch and remove it by using the tweezers to press the hinge into the device.
    • Remove the black screw located underneath where the battery hatch was.
    Pergunte ao FixBot
    Comentar
  9. Osmo Mobile Bluetooth Module Replacement: passo 9, imagem 1 %32 Osmo Mobile Bluetooth Module Replacement: passo 9, imagem 2 %32
    • Use the spudger to remove the front handle casing by sliding the spudger into the area between the handle grooves.
    • Slide the spudger around the groove to find the 6 clasps that hold the front part of the handle, and unclasp them.
    • Take off the front handle section to reveal the whole interior of the device.
    Pergunte ao FixBot
    Comentar
  10. Osmo Mobile Bluetooth Module Replacement: passo 10, imagem 1 %32 Osmo Mobile Bluetooth Module Replacement: passo 10, imagem 2 %32 Osmo Mobile Bluetooth Module Replacement: passo 10, imagem 3 %32
    • Locate and remove the black screw in the center of the motherboard chip.
    • Remove motherboard and replace.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
USF Tampa, Team S2-G1, Nance Fall 2017 Membro de USF Tampa, Team S2-G1, Nance Fall 2017
USFT-NANCE-F17S2G1
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 39
Ao todo: 2,275
