Ir para o conteúdo principal
Orbic Wonder Battery Replacement
O que você precisa
  1. Orbic Wonder Battery Replacement, Battery: passo 1, imagem 1 %32 Orbic Wonder Battery Replacement, Battery: passo 1, imagem 2 %32 Orbic Wonder Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove two 2mm TR9 Torx screws from the bottoms of the device.
    Pergunte ao FixBot
    Comentar
  2. Orbic Wonder Battery Replacement: passo 2, imagem 1 %32 Orbic Wonder Battery Replacement: passo 2, imagem 2 %32 Orbic Wonder Battery Replacement: passo 2, imagem 3 %32
    • There is a border between the black phone backing and the silver screen.
    • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
    • When the halves are parted correctly, the gap should look like this.
    • Be careful to avoid damaging any connecting circuitry between the two halves.
    Pergunte ao FixBot
    Comentar
  3. Orbic Wonder Battery Replacement: passo 3, imagem 1 %32 Orbic Wonder Battery Replacement: passo 3, imagem 2 %32 Orbic Wonder Battery Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
    • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
    • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
    Pergunte ao FixBot
    Comentar
  4. Orbic Wonder Battery Replacement: passo 4, imagem 1 %32 Orbic Wonder Battery Replacement: passo 4, imagem 2 %32 Orbic Wonder Battery Replacement: passo 4, imagem 3 %32
    $3.99
    • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
    • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
    Pergunte ao FixBot
    Comentar
  5. Orbic Wonder Battery Replacement: passo 5, imagem 1 %32 Orbic Wonder Battery Replacement: passo 5, imagem 2 %32 Orbic Wonder Battery Replacement: passo 5, imagem 3 %32
    • There is a black flap on the bottom of the battery.
    • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
3Comentários do guia
where do you buy the replacement battery at ?
ricotoomo - Responder Compartilhar
Where can I buy a replacement battery
Robert Smith - Responder Compartilhar
Thank you big help your smart
gansterms123 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 59
Ao todo: 8,209
