Ir para o conteúdo principal
Oral-B iO Battery Replacement
O que você precisa
  1. Oral-B iO Battery Replacement, Unfasten bottom cap: passo 1, imagem 1 %32 Oral-B iO Battery Replacement, Unfasten bottom cap: passo 1, imagem 2 %32
    • Before you start, disconnect the charging station from the power socket.
    • Flip the charging station of your Oral-B iO upside down.
    • Align the three recesses on the iO's silver bottom cap with the notches at the bottom of the charging station.
    • Push the toothbrush into the charging station with mild pressure and turn it about 90° counter clockwise to unlock the thread of the bottom cap.
  2. Oral-B iO Battery Replacement, Bottom cap removal: passo 2, imagem 1 %32
    • Unscrew the bottom cap of your toothbrush.
    • Remove the bottom cap.
  3. Oral-B iO Battery Replacement, Pry up the metal ring: passo 3, imagem 1 %32 Oral-B iO Battery Replacement, Pry up the metal ring: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • It is possible that toothpaste residues or lime have accumulated underneath the metal ring above the gray rubber gasket. For this reason, the ring may behave somewhat stubbornly during removal.
    • Insert one arm of a pair of tweezers or a small flathead screwdriver underneath the bottom edge of the metal ring sitting above the grey rubber gasket.
    • Use your tool to carefully pry up the metal ring.
    • The metal ring is held in place by small plastic clips. During reassembly make sure, it snaps back into place.
    • When prying up the metal ring be careful not to puncture or tear the grey rubber gasket.
  4. Oral-B iO Battery Replacement, Remove the metal ring: passo 4, imagem 1 %32 Oral-B iO Battery Replacement, Remove the metal ring: passo 4, imagem 2 %32
    • Use a pair of tweezers or your finger to remove the metal ring.
    • This is a good point during reassembly to clean off toothpaste residues and lime from the gasket and the metal ring. However avoid using liquid cleaners or use them in very small amounts. With the removed metal ring they can run easily inside the toothbrush causing water damage.
  5. Oral-B iO Battery Replacement, Remove toothbrush assembly: passo 5, imagem 1 %32 Oral-B iO Battery Replacement, Remove toothbrush assembly: passo 5, imagem 2 %32 Oral-B iO Battery Replacement, Remove toothbrush assembly: passo 5, imagem 3 %32
    • Remove the brush head from your toothbrush.
    • Hold the toothbrush body in one hand and use your thumb to press down the top of the toothbrush assembly.
    • Pull the toothbrush assembly out of the opening at the bottom end of the toothbrush body.
  6. Oral-B iO Battery Replacement, Battery removal: passo 6, imagem 1 %32 Oral-B iO Battery Replacement, Battery removal: passo 6, imagem 2 %32
    • Do not use excessive force or pry at the battery with metal tools.
    • Pull the battery out of its recess on the bottom of the toothbrush assembly.
    • In case the battery sits to tight in its recess, you can use a plastic tool like a spudger to pry the battery out of its recess.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
Conclusão
If possible, turn on your toothbrush and test your repair before resealing.
81 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
229.498 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.455 guias
69 comentários
thank you for this tutorial! any idea how to source a battery for it? Couldn’t find a 0307 740 mh type
M Marco - Responder
can you tell what is the size of battery (dimensions) ? it’s LiOn but what is the form factor of it?
marcinlag - Responder
14500 is the form factor. See comment below
John McEntee -
Thank you for your tutorial, it allowed me to fix a dropped toothbrush
martin - Responder
My toothbrush got knocked over on the counter and it started doing this weird loop of booting but not going into the menu, and doing and doing it. Until it shows the battery is at 0%. Just ordered the battery and hopefully that was just the issue and that the knocking over was just coincidental. I opened it up and no parts just randomly fell out and checked the circuit board it and nothing looked like it got knocked out of place.
Albion Ong -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 441
Últimos 7 dias: 3,115
Últimos 30 dias: 11,303
Duração total: 376,433
