Ir para o conteúdo principal
Oral-B Black 7000 Induction Coil Replacement
O que você precisa
  1. Oral-B Black 7000 Induction Coil Replacement, Induction Charging Coil: passo 1, imagem 1 %32 Oral-B Black 7000 Induction Coil Replacement, Induction Charging Coil: passo 1, imagem 2 %32 Oral-B Black 7000 Induction Coil Replacement, Induction Charging Coil: passo 1, imagem 3 %32
    • Use the charging station to remove the a small plastic plug from the end of the toothbrush by inserting the charging station into the end insert and twisting counter-clockwise by 90 degrees.
  2. Oral-B Black 7000 Induction Coil Replacement: passo 2, imagem 1 %32
    • Remove the end cap from the bottom of the toothbrush by prying it off with a spudger.
  3. Oral-B Black 7000 Induction Coil Replacement: passo 3, imagem 1 %32
    • Remove the top cap by using a spudger to pry the plastic ring off of the toothbrush frame.
  4. Oral-B Black 7000 Induction Coil Replacement: passo 4, imagem 1 %32 Oral-B Black 7000 Induction Coil Replacement: passo 4, imagem 2 %32
    • Use a spudger to loosen the two plastic tabs next to the induction coil that secure the internal assembly to the frame.
    • Push on the rotating head in order to pop the assembly out of the black plastic casing.
    • You can also use a spudger to leverage the assembly out, but this may break the copper wire connected to the induction coil, so be careful.
  5. Oral-B Black 7000 Induction Coil Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Unwrap the ends of the wires from the white plastic pegs using a pair of tweezers.
    • Each wire end is wrapped around the peg 3-4 times.
  6. Oral-B Black 7000 Induction Coil Replacement: passo 6, imagem 1 %32
    • Melt the solder at the two pads on either side of the top of the motherboard. This will require a high heat soldering iron. Remove the wire from the solder pads using tweezers once the solder melts.
  7. Oral-B Black 7000 Induction Coil Replacement: passo 7, imagem 1 %32
    • Remove the induction coil by pulling the plastic tabs out of their keepers.
    • A spudger can be used to remove the plastic tabs from their keepers if neccessary.
Conclusão
Equipe
IUPUI, Team S1-G1, Harley Fall 2017 Membro de IUPUI, Team S1-G1, Harley Fall 2017
IUPUI-HARLEY-F17S1G1
Membros da 3
Autoria de 16 guias
2 comentários
bonjour, ou puis je trouver une nouvelle bobine d’induction ou puis je remplacer simplement le fil de cuivre
Geoffrey Sacré - Responder
juste une précision pour sortir l’intérieur de la brosse du manche il faut appuyez sur les deux pattes plastique en bas près de la boucle d’induction
on voit une des pattes a l’étape 5
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 35
Últimos 30 dias: 164
Duração total: 4,539
