Ir para o conteúdo principal
Optoma HD20 Focal Lens Replacement
O que você precisa
  1. Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: passo 1, imagem 1 %32 Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: passo 1, imagem 2 %32
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    Pergunte ao FixBot
    Comentar
  2. Optoma HD20 Focal Lens Replacement: passo 2, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    Pergunte ao FixBot
    Comentar
  3. Optoma HD20 Focal Lens Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
    Pergunte ao FixBot
    Comentar
  4. Optoma HD20 Focal Lens Replacement: passo 4, imagem 1 %32
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    Pergunte ao FixBot
    Comentar
  5. Optoma HD20 Focal Lens Replacement, Focal Lens: passo 5, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the small black 2 mm screw on the side of the focal lens.
    Pergunte ao FixBot
    Comentar
  6. Optoma HD20 Focal Lens Replacement: passo 6, imagem 1 %32
    • Remove the focal lens by twisting it clockwise until it comes off.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Trever
Membro desde: 01/22/15
1.282 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 21-23, Maness Winter 2015 Membro de Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 53
Ao todo: 4,818
