Ir para o conteúdo principal
Optoma HD20 Air Filter Replacement
O que você precisa
  1. Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: passo 1, imagem 1 %32 Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: passo 1, imagem 2 %32
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    Pergunte ao FixBot
    Comentar
  2. Optoma HD20 Air Filter Replacement: passo 2, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    Pergunte ao FixBot
    Comentar
  3. Optoma HD20 Air Filter Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
    Pergunte ao FixBot
    Comentar
  4. Optoma HD20 Air Filter Replacement: passo 4, imagem 1 %32
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    Pergunte ao FixBot
    Comentar
  5. Optoma HD20 Air Filter Replacement, Air Filter: passo 5, imagem 1 %32 Optoma HD20 Air Filter Replacement, Air Filter: passo 5, imagem 2 %32 Optoma HD20 Air Filter Replacement, Air Filter: passo 5, imagem 3 %32
    • Carefully peel off each air filter from the device
    • Pull up on the air filter to remove it.
    Pergunte ao FixBot
    Comentar
  6. Optoma HD20 Air Filter Replacement: passo 6, imagem 1 %32
    • Remove the air filter from the device.
    • Try not to deposit dirt from the air filter into the inside of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Trever
Membro desde: 01/22/15
1.282 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 21-23, Maness Winter 2015 Membro de Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Membros
Autoria de 6 guias
1Comentário do guia
There were no filters where the photos indicate.
Michael - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 15
Últimos 30 dias: 69
Ao todo: 13,565
