Ir para o conteúdo principal
Oppo X9000 Power Button Replacement
O que você precisa
  1. Oppo X9000 Power Button Replacement, Removing the Back Cover: passo 1, imagem 1 %32 Oppo X9000 Power Button Replacement, Removing the Back Cover: passo 1, imagem 2 %32
    • Turn the phone over so that you are facing the back side of the phone.
    • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
    • Completely remove the back cover by moving down the sides and bottom with your fingers.
    Pergunte ao FixBot
    Comentar
  2. Oppo X9000 Power Button Replacement, Removing the Battery: passo 2, imagem 1 %32
    • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
    Pergunte ao FixBot
    Comentar
  3. Oppo X9000 Power Button Replacement, Remove the Back Panel Screws: passo 3, imagem 1 %32 Oppo X9000 Power Button Replacement, Remove the Back Panel Screws: passo 3, imagem 2 %32
    • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
    • Store all the screws in a safe place where you will not lose them.
    Pergunte ao FixBot
    Comentar
  4. Oppo X9000 Power Button Replacement, Remove the Rubber Stoppers: passo 4, imagem 1 %32 Oppo X9000 Power Button Replacement, Remove the Rubber Stoppers: passo 4, imagem 2 %32
    • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
    Pergunte ao FixBot
    Comentar
  5. Oppo X9000 Power Button Replacement, Remove the Newly Exposed Screws: passo 5, imagem 1 %32
    • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
    Pergunte ao FixBot
    Comentar
  6. Oppo X9000 Power Button Replacement, Lift off the Back Panel: passo 6, imagem 1 %32 Oppo X9000 Power Button Replacement, Lift off the Back Panel: passo 6, imagem 2 %32
    • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
    Pergunte ao FixBot
    Comentar
  7. Oppo X9000 Power Button Replacement, Remove the Power Button Bracket: passo 7, imagem 1 %32
    • Use the sharp end of the spudger to pry the power button bracket from the side of the rear case.
    Pergunte ao FixBot
    Comentar
  8. Oppo X9000 Power Button Replacement, Let the Button Fall Out: passo 8, imagem 1 %32
    • Rotate the phone onto its side so that the power button falls out with ease.
    • Make sure not to lose the power button.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Joe Hanacek
Membro desde: 10/14/14
562 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-45, Amido Fall 2014 Membro de Cal Poly, Team 4-45, Amido Fall 2014
CPSU-AMIDO-F14S4G45
5 Membros
Autoria de 22 guias
1Comentário do guia
I am having trouble with my buttons as they no long spring back after i replaced the speaker. They now just sit flush with the body of the phone, both buttons and metal brackets are installed.
Any ideas?
Jake Karp - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 35
Ao todo: 4,156
