Ir para o conteúdo principal
Open Case
O que você precisa
  1. Open Case, Open Case: passo 1, imagem 1 %32 Open Case, Open Case: passo 1, imagem 2 %32 Open Case, Open Case: passo 1, imagem 3 %32
    • Clean the coffee machine before starting as well as possible and remove any remaining coffee bean debris, etc.
    • Pull the power plug before working on the coffee machine!
    • Never submerge the coffee machine completely under water.
    • Remove the drip pan, tray and container for used coffee,...
    • ... the water tank, ...
    • and the aroma protection cover.
    Pergunte ao FixBot
    Comentar
  2. Open Case: passo 2, imagem 1 %32 Open Case: passo 2, imagem 2 %32
    • One hurdle: the back is attached with four special oval-head screws. They look like rivets. To remove them, you need an oval-head bit. In a pinch, you can also use a good pair of pliers.
    Pergunte ao FixBot
    Comentar
  3. Open Case: passo 3, imagem 1 %32 Open Case: passo 3, imagem 2 %32
    • Remove the two T15 Torx screws from the coffee machine housing cover.
    Pergunte ao FixBot
    Comentar
  4. Open Case: passo 4, imagem 1 %32 Open Case: passo 4, imagem 2 %32
    • Remove the top cover of the coffee machine.
    Pergunte ao FixBot
    Comentar
    • Remove the panel from the right side.
    • Slightly lift the side panel at the back and then pull it out backwards with a little effort. Especially when disassembling it for the first time, the force required for this can be quite high.
    Pergunte ao FixBot
    Comentar
    • Remove the left side panel.
    • A light tap on the back of the recess for the water tank can help to loosen the side panel.
    Pergunte ao FixBot
    Comentar
Conclusão
Do you need help extracting the grinder of your Jura Impressa F50 to service it or replace it? Then check out the guide "Extract and Replace Grinder".
13 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Natalie
Membro desde: 05/08/19
756 Reputação
Autoria de 4 guias
Equipe
KMM 2019SS Membro de KMM 2019SS
Community
11 Membros
Autoria de 16 guias
1Comentário do guia
hi thank you!
Amberr - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 39
Últimos 30 dias: 205
Ao todo: 15,967
