Ir para o conteúdo principal
OontZ Angle 3 Speaker Replacement
O que você precisa
  1. OontZ Angle 3 Speaker Replacement, Back Case: passo 1, imagem 1 %32 OontZ Angle 3 Speaker Replacement, Back Case: passo 1, imagem 2 %32 OontZ Angle 3 Speaker Replacement, Back Case: passo 1, imagem 3 %32
    • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
    • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
  2. OontZ Angle 3 Speaker Replacement: passo 2, imagem 1 %32
    • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
  3. OontZ Angle 3 Speaker Replacement: passo 3, imagem 1 %32 OontZ Angle 3 Speaker Replacement: passo 3, imagem 2 %32
    • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
  4. OontZ Angle 3 Speaker Replacement, Speaker: passo 4, imagem 1 %32 OontZ Angle 3 Speaker Replacement, Speaker: passo 4, imagem 2 %32
    • Use the plastic opening tool to remove the front speaker plate from the speaker.
  5. OontZ Angle 3 Speaker Replacement: passo 5, imagem 1 %32 OontZ Angle 3 Speaker Replacement: passo 5, imagem 2 %32
    • Remove the eight (8) 5.25mm screws with the Phillips #0 screwdriver.
    • Open access to the speakers by letting them rest as shown.
  6. OontZ Angle 3 Speaker Replacement: passo 6, imagem 1 %32 OontZ Angle 3 Speaker Replacement: passo 6, imagem 2 %32
    • Use the soldering iron to carefully disconnect the speaker(s) from the motherboard connection wires.
    • Learn more about soldering here.
    • Remove the disconnected speaker(s).
    • When reconnecting the wires to the new speaker(s), be careful to connect the wires to the correct nodes (red for positive and black for negative). If they are reconnected to the wrong locations the speakers will either not work or break.
Conclusão
10 outras pessoas executaram este guia.
Mason Hollander
Membro desde: 01/20/16
1.387 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 15-6, Remmell Spring 2016 Membro de USF Tampa, Team 15-6, Remmell Spring 2016
USFT-REMMELL-S16S15G6
Membros da 4
Autoria de 4 guias
7 comentários
Where do you buy replacement speakers?
michalfiona - Responder
Where do you buy the replacement speakers?
What type to buy?
where i buy the speaker replacement/
Sharina Uadan - Responder
Where can i buy the replacement speakers
Anil Meda - Responder
same question, I am looking for original speaker for oontz angle 3 and I can’t find one. Those who are looking for the size, its 40x40mm (1.57”) 4ohms 3W
Dwayne Champ Manuel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 97
Duração total: 8,295
