Introdução
In this guide, some soldering is required when disconnecting the speakers from the motherboard. If you are unfamiliar with soldering, watch Soldering Tutorial for Beginners, Five Easy Steps to familiarize yourself and to be able to correctly replace the speakers.
O que você precisa
Use the plastic opening tool to remove the rubber caps from each end of the speaker.
Use the plastic opening tool to remove the front speaker plate from the speaker.
10 outras pessoas executaram este guia.
7 comentários
Where do you buy replacement speakers?
Where do you buy the replacement speakers?
What type to buy?
where i buy the speaker replacement/
same question, I am looking for original speaker for oontz angle 3 and I can’t find one. Those who are looking for the size, its 40x40mm (1.57”) 4ohms 3W
