Ir para o conteúdo principal
OnePlus One Micro USB Port Replacement
O que você precisa
  1. OnePlus One Micro USB Port Replacement, Battery: passo 1, imagem 1 %32 OnePlus One Micro USB Port Replacement, Battery: passo 1, imagem 2 %32 OnePlus One Micro USB Port Replacement, Battery: passo 1, imagem 3 %32
    • Remove the SIM tray.
    • Using a plastic opening tool, carefully separate the back panel from the main body assembly of the phone. Be extra careful around the SIM slot or other weak areas.
    • You may encounter some resistance due to hidden locking clips around the inside edge of the phone. Not to worry; just move in one consistent direction around the phone as opposed to jumping from spot to spot!
    • Top to bottom, left to right, clockwise or counter clockwise, once we make it about half way around the device, the panel is easily removable by hand.
    • It is of utmost importance that you do not attempt to free the battery from the device at this point without proceeding to the following step! This is an integrated battery that can easily be damaged or destroyed if the proper steps are are not taken.
    Pergunte ao FixBot
    Comentar
  2. OnePlus One Micro USB Port Replacement: passo 2, imagem 1 %32 OnePlus One Micro USB Port Replacement: passo 2, imagem 2 %32 OnePlus One Micro USB Port Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers, remove the plastic plugs.
    • Once the hidden screws are revealed, use a PH #00 screwdriver to remove the three 3.175mm screws.
    • Use the PH #00 screwdriver to remove the remaining six 3.175 screws.
    Pergunte ao FixBot
    Comentar
  3. OnePlus One Micro USB Port Replacement: passo 3, imagem 1 %32
    • Using a plastic opening tool, gently pry up the black plastic cover and remove it from the device.
    Pergunte ao FixBot
    Comentar
  4. OnePlus One Micro USB Port Replacement: passo 4, imagem 1 %32 OnePlus One Micro USB Port Replacement: passo 4, imagem 2 %32 OnePlus One Micro USB Port Replacement: passo 4, imagem 3 %32
    • After we have removed the motherboard cover, we notice that the battery is intact and has a black ribbon attached to it, which is mounted on the logic board.
    • Using the spudger, carefully begin to lift the the battery up from the side opposite the ribbon. Be aware that there is high-grade adhesive holding the battery in its bay, so proceed with caution.
    • This battery is not encased in a hard shell so it is soft and malleable. Caution must be taken during removal so as not to cause permanent damage.
    Pergunte ao FixBot
    Comentar
  5. OnePlus One Micro USB Port Replacement: passo 5, imagem 1 %32 OnePlus One Micro USB Port Replacement: passo 5, imagem 2 %32 OnePlus One Micro USB Port Replacement: passo 5, imagem 3 %32
    • Once the battery has been freed, we use the ever handy black spudger to pry up and free the battery ribbon from its dock.
    • You can disconnect the battery before freeing it to make removal easier.
    Pergunte ao FixBot
    Comentar
  6. OnePlus One Micro USB Port Replacement, Removing the Lower Back Panel Assembly: passo 6, imagem 1 %32 OnePlus One Micro USB Port Replacement, Removing the Lower Back Panel Assembly: passo 6, imagem 2 %32 OnePlus One Micro USB Port Replacement, Removing the Lower Back Panel Assembly: passo 6, imagem 3 %32
    • Once the battery has been removed, we shift our attention to the back panel assembly. This piece is held together by six screws. See info note below.
    • Luckily, the OnePlus One was assembled with all of the same size screws save for the one holding down the motherboard. All of these screws are philips 00 and 3.175 mm. in lenght.
    • Using the spudger we pry open the panel assembly and, behold, we have access to the micro usb port. You can also use a blue opening tool if you prefer.
    • Keep in mind that there are two hidden screws. Both are located beneath plastic plugs. Tweezers are an effective tool for removing the plugs.
    Pergunte ao FixBot
    Comentar
  7. OnePlus One Micro USB Port Replacement, Freeing the micro USB Connector and Attached Ribbon from Daughterboard: passo 7, imagem 1 %32 OnePlus One Micro USB Port Replacement, Freeing the micro USB Connector and Attached Ribbon from Daughterboard: passo 7, imagem 2 %32 OnePlus One Micro USB Port Replacement, Freeing the micro USB Connector and Attached Ribbon from Daughterboard: passo 7, imagem 3 %32
    • Now that we have access to the usb port, we use the flat end of or spudger and lift it off of its connector and free it from the daughterboard.
    Pergunte ao FixBot
    Comentar
  8. OnePlus One Micro USB Port Replacement, Freeing the USB Ribbon: passo 8, imagem 1 %32 OnePlus One Micro USB Port Replacement, Freeing the USB Ribbon: passo 8, imagem 2 %32 OnePlus One Micro USB Port Replacement, Freeing the USB Ribbon: passo 8, imagem 3 %32
    • Now it is time to remove the ribbon. You will notice that there is a small strip of black tape keeping us from from completely freeing it. Not to worry. Simply use the spudger to maneuver the tape out of the way.
    • Your micro USB and attached ribbon are now free to be removed.
    Pergunte ao FixBot
    Comentar
Conclusão
33 outras pessoas executaram este guia.
Chad Jackson
Membro desde: 09/22/14
5.370 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 3-3, Brown Fall 2014 Membro de USF Tampa, Team 3-3, Brown Fall 2014
USFT-BROWN-F14S3G3
3 Membros
Autoria de 24 guias
4Comentários do guia
Thanks back up and working should get a few more years out of it
cheers
robert storrs - Responder Compartilhar
Pretty easy, just be really careful when removing battery from glue ;)
Thanks a lot for this guide which is really complete !
Gael Augeat - Responder Compartilhar
I was able to successfully follow these instructions. Pretty sure I damaged the battery during removal though. I intended to replace the battery anyways, so I’m not too worried about it, but it would be nice to to have some technique listed for removing it less destructively.
George Simpson - Responder Compartilhar
For me USB was not charging because it seems that one of the 2 USB plugs above the battery were loose. I did replace the battery already sometime far in the past so this might have been the cause. If you just want to re-plug on the upper side and lift the port on the lower side, you don't even need to remove the battery. Just make sure that all plugs, not just USB, are tight before screwing everything back together.
Thanks a lot for this guide!
Robert Gutjahr - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 109
Ao todo: 38,753
